JSZ JSZ is online now
SSI Installation
After a great deal of reading and planning, i thought my SSI installation would have gone smoothly.
I recently purchased a pair of thick flange, SSI that were new old stock. I was reassured they were correct for a stock 82 SC. I went through the oil line install no real issues I could not tackle. However when I went to install the SSI's they would only go up about flush with the studs and the flanges. So I took some measurements, my port sizes are 38.60mm, the belled portion of the SSI's above the flange averaged about 39.50mm.
I believe the two SSI part numbers are 484122 and 434646
So I have a few ideas, shrink the tubing or other thoughts?
Thank you for your assistance.
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 02-21-2019, 03:52 AM
Those heatboxes are specific for Carrera.
The inserts on 3.2 are larger than the 3.0.
Usually the SC pipes are used on Carrera and no one would notice an improper fit.
Bruce
Old 02-21-2019, 04:52 AM
Registered Minimalist
75 911s's Avatar
Yep. They make two "thick flange" SSI. I have the other style without the insert on my 75.
You need the other style as well, although desperate people have cut the inserts off (bad idea imho.)
Duane
http://forums.pelicanparts.com/porsche-911-technical-forum/878569-born-75-me-my-new-911s.html
Old 02-21-2019, 05:14 AM
Have not considered cutting the inserts off. Thinking I can swage these with a die Or possibly 1 or 2 vertical cuts in the insert to allow for the excess material take up, then tig close.
Well all good intentions don’t always work with out more thoughts and efforts.
Thanks much.
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 02-21-2019, 05:31 AM
3.0 vs 3.2 SSI
I installed a new set for my 82 3.0 a few years ago before SSI was sold to Dansk. I had the pleasure of speaking to John a few times, and he was rightfully proud of his product.
I was absolutely amazed at how well they fit, the the little port inserts were absolutely spot on.
I know it would would be a hassle to try and swap them out, but please try before you hack off the insert sections. They are metal works of art from a small California business that no longer exists...
Old 02-21-2019, 05:55 AM
Don’t cut them off, they are correct for an 82 SC US spec.
I also have an 82 SC and installed the SSIs with inserts like you have pictured. They didn’t want to fit at first but I used a brass brush on a dremel to clean out the ports on the heads a little and they fit fine after that. Just make sure you rotate the crank to close the exhaust valve for the cylinder you are working on.
_______________________________
1982 911 SC 230,000mi and counting
Old 02-21-2019, 01:18 PM
Just an FYI - if you run into issues and would rather get out of them and buy another set for your SC, I have a Carerra 3.2 and would be willing to buy the set you have from you. Feel free to PM me - if not, keep us posted on your install with pics and feedback on how you like them. I am considering taking the same route but need to research the changes to oil line and heater pipes ... regardless, I definitely want to do this as well as the Steve Wong chip.
Old 02-22-2019, 09:02 AM
I finally have had some time to complete the rework of the SSI's for install on my 82 SC. I had my son machine a die that was drawn down on to the insert and swaged it from 39.4mm to 38.43mm. Absolutely worked perfect and fit right up. The biggest issue was there were only two access holes and not the three through the heat exchanger for the barrel nuts. So I installed a copper nut in lieu of the barrel at the missing access hole.
So if someone has this issue in the future I have the tooling to allow for the fitment to an SC
Photo 1 is the die, two and three shows the inserts after swaging
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 03-18-2019, 05:18 PM
Nicely done Jeff!
Jason
'79 911SC Targa
Old 03-18-2019, 05:24 PM
nice fix ! I got a used set of SSIs without those insert sleeves and has been running that for about 10 years now without any issues (leaks)
80SC (ex California) 3.2SS
Old 03-18-2019, 10:57 PM
Completed the SSI installation, long road, however satisfied with the results.
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 03-19-2019, 05:12 PM
Here are a few photos of the die in use for the sawging process. It is a two step process with a taper drawn on first and then the die is flipped over and drawn down with the straight side to achieve the shrinking of the insert.
Jeff
1982 911SC
1973 TR6
1979 124 Spider
1978 124 Spider
Old 03-20-2019, 05:08 AM
Thoughtful and instructive. Thanks. John
Old 03-20-2019, 01:03 PM
