That's fond- just deglaze
1986 Alternator replacement- Rumbling noise now gone, hidden bolt on A/C plate
Background: 1986 3.2 Coupe, now with 140K.
The issue: A low rumbling growl that could also be felt when I placed my hand on the fiberglass shroud cover. I first noticed it two years ago, and it has been getting progressively louder. (It was getting especially loud at idle.)
It was the exact same sound as 911 Euro posted: 1984 Porsche 911 Euro Engine Noise on his YouTube link. https://www.youtube.com/watch?v=7O5r2Cu5yQc&feature=youtu.be
Checked her records, and the alternator was last changed in 1996. All indications (I hoped) pointed to alternator bearings going bad. Plus, I really wanted to clean up the Magnesium fan and housing.
I had the damnedest time trying to loosen the A/C compressor plate to remove the belt. As it turns out, I really need to read the manual better. There are four (M8 Hex) Bolts holding down the plate. The one on the upper right side is absolutely buried- you have to find it by touch!
The alternator replacement process (using a rebuilt Bosch unit) was relatively straightforward. I used all new hardware from our host, and I used 4 outside, 2 inside for Pulley Shim placement.
The Result: Noise is gone, new (Porsche-branded) belts and a clean fan and shroud. As an aside, I used Purple Power and a Scotch-Brite pad on the Mg- seemed to work well.
Missed Approach
Petra- 1986 Coupe
Old 07-16-2019, 08:58 AM
If you spray the magnesium with Boshield or Gibbs the finish will last longer
Old 07-16-2019, 09:16 AM
Thanks @911obgyn! That was a concern- there appears to be a West Marine near me that has Boeshield in stock!
Missed Approach
Petra- 1986 Coupe
Old 07-16-2019, 12:02 PM
