Counterclockwise?
Boots for tie rod ends
Does anyone know if you can buy boots for turbo tie rod ends?
One of mine is ripped.
Rod
1986 Carrera
2001 996TT
Old 02-22-2019, 06:50 AM
Senior Member
Jdub's Avatar
Not that I am aware of. However, if this has gone unattended you will certainly do better to just R&R your current pair (both sides).
Perform a search and query the group about good vs. bad rubber on different tie rod ends from our available vendors. Some are good, some not so much and you will be where you are today in short order.
'78 Targa in Minerva Blue
Old 02-22-2019, 09:44 AM
Counterclockwise?
Not quite sure what you are referring to. Replace the tie rods?
I think the boots ripped because the car spends too much time in the air.
Rod
1986 Carrera
2001 996TT
Old 02-22-2019, 10:10 AM
911T '72
DeRRis's Avatar
You can get boots at a local auto parts store just take the old one with you. But I would change your tie rods because it looks like there’s dirt in there.
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 02-22-2019, 01:51 PM
ball joints. Replace them, they're easy to do and cheap. Buy the special tool to wrench it off.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/57-Ball_Joint/57-Ball_Joint.htm
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago
89 944S2 Daily Driver-Sold because...still thinking why.
73.5CIS Targa Shed Find -On the Road Again
Old 02-22-2019, 03:14 PM
Senior Member
Jdub's Avatar
Ha! Sorry for the confusion. Basically it looks like they are contaminated, so replace, and the rubber used for certain suspension components (beyond just the item you need) can be pretty divergent. Some vendors use more plastic and thus the rubber is less elastic, more brittle, and tends to team earlier than others.
Old 02-22-2019, 03:18 PM
Counterclockwise?
Robert. Why would I replace ball joints? lol
I contacted the manufacturer and they are sending me a new set under warranty.
I'll update when I receive them.
Rod
1986 Carrera
2001 996TT
Old 02-25-2019, 06:23 AM
