-   -   ER trailing arm bushing install with arm in the car? (http://forums.pelicanparts.com/porsche-911-technical-forum/1021867-er-trailing-arm-bushing-install-arm-car.html)
Maxhouse97 02-23-2019 04:14 PM
I’ve watched Chuck do this on his YouTube video, without disconnecting the other side of the arm. My question is what trick can I use to get the arm lower on the front end? I hung my 185 lbs off the end and I couldn’t get it clear. Any ideas?
http://forums.pelicanparts.com/uploa...1550967116.jpg
mo-mon 02-24-2019 12:11 AM
I believe you have to remove the lower shock bolt out of the arm. Be careful of the brake lines as you lower the arm.
Maxhouse97 02-24-2019 03:38 AM
Yep of I’ll try that, that’s easy
