Harpo's Avatar
Welding in new weld stud for ground
Good afternoon everyone,
I'm relocating my battery to the smugglers box. I want to install a new M10 ground stud in the box. Although there were a few M6 I didn't want to use those
Before welding on my car what do I need to disconnect/isolate before welding so I don't damage any of the electronics?
Old 03-03-2019, 09:10 AM
175K911's Avatar
Why not just run a bolt through and not worry about welding?
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 03-03-2019, 09:37 AM
Harpo's Avatar
I had considered that but I was concerned about loosing my ground due to corrosion. I also considered a nut , bolt and soldering them together to ensure a good ground
Old 03-03-2019, 09:45 AM
Under the radar
Trackrash's Avatar
I ran a bolt through the sheet metal AND soldered the bolt head to the body. BTW, I used a large soldering iron.
On your '74, with the battery out of the car, I can't imagine you could cause any problems with the electrics on the car. Just make sure you have a very good ground from your welder as close to the weld as possible.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-03-2019, 09:58 AM
Harpo's Avatar
Thanks everyone
Old 03-03-2019, 10:15 AM
If there's a computer in the system, best to unplug it. A good way to attach a stud to sheet metal is to grind the head of a bolt flat and thin, pop it through a drilled hole and weld the backside.
206 637 4071
Old 03-03-2019, 11:20 AM
I would rather be driving
jpnovak's Avatar
You could also gas weld or braze. I like brazing since it is less prone to rust at the joint. Many factory ground posts are brazed.
Old 03-03-2019, 03:50 PM
