Engine keeps running after ignition key is turned off
I have a 1979 SC backdated to a 911R that I bought from Jim Tweet on here. The built post is on Pelican as well.
The engine is pimped out with ITB’s, EFI and an AEM Infinity ECU. If I turn the ignition key to off, the engine will keep running until I press the brake pedal. What could cause this? How do I fix it? Dan |
Plenty of threads on this. Do a search.. You will need a new or to add a diode.
| All times are GMT -8. The time now is 08:50 AM. |
