MrScott's Avatar
How to remove brake/seat belt warning light?
I've got the clock out and the wires disconnected so I can reach it from behind. I feel tabs on either side but squeezing them doesn't seem to help. I've also got the face/lense off and I see tabs there as well but I'd rather not pry them if it's not going to help, 30 year old plastic and all.
Note to anyone trying to reach it from below, not possible. Removing the radio only exposes a metal barrier.
Old 11-22-2009, 11:28 AM
schoward's Avatar
try putting wire harness back on and grab the wire bunch and give it a push as you squeeze the tabs. give it a little wiggle back and forth. mine popped right out doing this.
Old 11-22-2009, 07:10 PM
group911@aol.co's Avatar
On one I recently pulled, I popped the red lens off and then the little tabs were easily accessed. The lens snapped back in no problem. It was an SC
Thanks,
Bob
group911@aol.com
Old 11-22-2009, 07:41 PM
MrScott's Avatar
Now I'm confused. Is it the tabs in the back or the tabs in the front that hold it in the dash?
1980 911SC
Old 11-22-2009, 07:54 PM
It's the tabs in the housing but to access them, I found it easier by removing the red lens.
Thanks,
Bob
group911@aol.com
Old 11-22-2009, 08:19 PM
MrScott's Avatar
Alright so those 4 tabs (2 top and 2 bottom) I saw when I removed the lens. Thanks.
1980 911SC
Old 11-22-2009, 08:27 PM
Yep. Gently pry them in to release the unit
Thanks,
Bob
group911@aol.com
Old 11-22-2009, 08:29 PM
nineball's Avatar
related question - anyone know the bulb # for replacement purposes?
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 11-23-2009, 05:23 AM
Wavey's Avatar
I believe the bulbs are manufactured into the base unit - not a plug-in, but may be replaceable by soldering?
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 11-23-2009, 05:49 AM
dshepp806's Avatar
That's what I thought, too.
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 11-23-2009, 11:20 AM
nineball's Avatar
well that sucks. i don't want to get into soldering a small item like that. guess i will learn to live with the burned out seat belt bulb.
Old 11-23-2009, 12:45 PM
DL Lawrence's Avatar
Hmmm..my seat belt warning light was out, so I ordered the replacement bulb for this unit from our host- then found this thread ... do these bulbs in fact need to be soldered in? or are they replaceable? The bulbs sure look "plug and play". Anybody know for sure?
Thanks-
Old 05-30-2010, 01:09 PM
schumicat's Avatar
the bulbs pull out. pelican sells them.
Old 05-30-2010, 01:31 PM
The bulbs are soldered onto the circuit board, at least on an 88.
I broke one trying to remove and replace with LED 74's.
I will have to remove per this thread and solder new lights in.
Old 03-05-2019, 10:23 PM
Flojo's Avatar
when out/deleted... any cool idea what to replace with? any cool stuff to Close that hole again?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-06-2019, 12:58 AM
What about some USB ports?
Old 03-06-2019, 01:18 AM
AutoBahned
RWebb's Avatar
put the remote light for the Valentine V-1 radar detector there...
Old 03-06-2019, 01:15 PM
