Starter motor won’t disengage
As title states I turn the key and not only won’t it start but when it goes back to the 12 o’clock position the starter won’t disengage. Keeps going. All relays look good. Thoughts? Thanks!
1982 SC |
1970 911 T
Starter
Ignition switch worned out .
Chewed up starter bendix teeth hanging up on chewed up ring gear teeth keeps the solenoid contacts together and the starter keeps cranking. Could be.
I had this problem on my ‘77 and it was I think the fuel pump relay- red one. Apparently starter goes through it? Try pulling relay or replace with the horn one and see what happens.
Rutager West 1977 911S Targa Chocolate Brown |
Relay was replaced and problem continued....thanks,
