Dirt road tires for an SC
I've been dormant on the forums for a couple years, and am looking forward to wrenching on cars again now that I am set up at my new home.
I live in a rural area, with really crappy roads (frost heave) and lots of dirt roads. They are rough enough that my 996 C4s just isn't fun to drive to and from home(to the extent that I am toying with selling it) and even my 2000 4runner takes a beating. So, what to do with my ratty old SC. I really miss driving it, and I had it out a fair bit last fall and even into the winter and found it did really well on the rough roads and even dirt roads... the suspension is much more compliant than many other cars I've driven, and the tires (16s... 245 in the back, 205 in the front) arent too wide, and have a fair bit of sidewall. Anyway, without going all Keen wannabee, I am thinking more and more that I should set up my pre-bruised SC to be better suited for the driving I do. I'm thinking I'll lift it 4" or so, put on some taller tires, put some amber fog lights on it for nightime driving on these narrow crappy roads (very sketchy at night sometimes in snow and fog) and a roof rack with a weatherproof bag for the kids schoolbags. I'm not looking to geek out on poseur upgrades... just want to maximize the use of this car within its original design and specs. With that in mind, if I re-indexed the torsion bars to lift it the 4" or so, would I be ok with the stock shocks? Also, does anyone have experience getting taller tires without modifying the fenders? There are some nasty, nasty potholes and I don't want to bend my fuchs, so I think a bit more sidewall would help. Has anyone else gone this route?
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 03-10-2019 at 07:43 PM.. |
4" is asking a lot of the front control arms I think. I am currently looking at this myself for my Rat Rod. My goal is determine how high, and how low, I can go on the stack parts. Front camber adjustment is only one of a few things that get screwy as you go up high. The best you could do (I think), and the best approach, on stock parts would be to raise the front ride height as I high as you can and still keep 1/2 degree of negative front camber. Less than that and the car won't handle they way it should. Typically one side will run out before the other, so crank on max negative camber and then stat going up. Once the lowest side hits -.5 degrees, and the ride heights are close left/right, adjust the other side camber to match -.5.
I think this will kind of set the rear height as the rear seems to have more room for adjustment (others would know better than I). Based on the spec's from the factory, you then can set the rear height to maintain the front/rear balance. Many say that is 1 degree of slope (front lower than rear) as measure on the for sill. I have found the factory had the front at about .615 of the rear if you are measuring torsion bar height. For example, the euro height measured at the torsion bar tubes is 108mm front and 16mm rear (torsion tube center height - axle center height). On my car, which has a 310 mm axle center this means Euro would be a torsion tube height of 202mm front and 326mm rear off the ground. 202/326 is .619. Other measurements I have found vary to .609, so .615 is the middle ground. Doing the math, if your rear torsion tube is 291mm off the ground (like I just raised mine to) then your front should be at 179mm off the ground. I hope this helps a little. There are others who are FAR more knowledgeable on this (like Bill V).
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Formerly known as Syzygy
I would think you're not gonna get any where near 4" higher with stock components. That's why Elephant and others have lowered the spindles on the Bilstein struts to raise the cars about 3" or so. In that way, the front dampers won't have to be altered, as well.
On the rear, there will be likely some shock length issues if you raise the car that much. I, too, have thought about trying to pick up another 911 to raise it for the snowy Alberta winters and playing on gravel and dirt back roads in the other four months of the year. ![]() Good luck with your project.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
UnRegistered User
Hey Jake!
Nice to see you back. No vehicle fires recently? How about non-haunted houses? Hope all is well!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
gearhead
4"? Nope. Not simple.
I read about a guy that ralleyed his classic 911 across country and used a pirelli truck tire
Scorpion maybe?
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Been laying low for a couple years, just finishing up building a new house and excited to have some garage time again!
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
I guess the question I should have asked is how much lift can I get without major mods? I've already bottomed out a few times and dented the front valance, torn the rubber front spoiler, and dented one of the rocker covers. I think a couple inches would make a big difference. I just don't want to get into a "while I'm at it" situation where I end up going bonkers on the car. It's rough and ratty, and I like it that way. I just want to be able to drive it more, and a bit harder.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 03-10-2019 at 07:44 PM.. |
Maybe a set of 15" cookie cutters so it doesn't mater what happens to them
and just buy tall 15" tires. I've found skinny tires grip better in loose gravel.And if you got bored one day you could fabricate up a skid plate for the bottom of the engine. |
Lower spindles 70mm, index the rear torsion cars and get some real rally tires (or snow tires). And welcome back!
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Is Elephant Racing the best source for lowered spindles, or is that a job I could DIY if I found a used set?
Thanks for the welcome back, pretty cool to see the same names again so quickly! Here's the car as it sits now:
I like the idea of throwing on a set of 15" cookie cutters for taller tires!
Disbanded
even if you were to lower the spindles the A-arm & tie-rod length could still be the issue to raise one 4". they are not long enough to span a raised suspension if at all akin to lowering one of these cars. neither will the trailing arms in the rear and if you were even able to go that high you'd need different shocks that could be hard to find. you might be able to raise it a couple inches by manipulating the stock ride height and maintain the budget you've set forth while keeping the intended suspension geometry..
are soft springs and purpose valved shocks better for the application you desire, or stiffer springs/torsion bars and shocks valved to suit that better? im not aware. might be cheapest to use the existing springs, the highest OE ride height you can get noting what ive mentioned above and having shocks purpose valved for the rough roads. maybe you can get it set up to drive around some, and handle other of these potholes.... what ever you do im watching!
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I don't want to screw with the shocks and torsion bars too much, especially when it comes to making anything stiffer... my C4S is stiff and NO FUN on these roads at all. Maybe 2" would be enough to save me flattening my oil lines. I've never seen a pic of a 911 at its max height adjustment.
Lowered spindles will net you about 2.75" up front. Reindexing the rear torsion bars should be able to match that but you'll need longer shocks. Perhaps talk to Chuck over at Elephant.
To lower the spindles, I believe you'll need Bilstein struts. I understand it's not a big job, but will require removing spindles and re-welding back on. You might also need longer brake lines and such, front and rear. I see no reason you can't use your existing torsion bars, front and rear. That way, damper valving shouldn't need to be adjusted unless you put on some really heavy tires and/or wheels on there.
What about just going a bit taller with th 16? Few grand touring/all season options at tire rack in 205/65-16 front and 225/60-16 rear - give you both around an inch more clearance and softer sidewalls at the expense of taller effective gearing-
This picture from that thread shows their car 3" above euro height... it seems like plenty to me: ![]() Quote:
I had a branch from a birch tree fall 20ft onto the roof of the car in the fall... I was pissed at first but now I feel like I've been liberated to do whatever I want with the car... not that it was a garage queen before that
Disbanded
the OP said he was on a budget...…
talking with chuck is not cheap!!!!look for some steely type wheels and put some skinny snow tires on the thing! have fall/summer/spring tires on aluminum rims and the snow studded pizza cutters for winter!
