Fuel lines
1974 911 targa 83,000 miles.
Tried firing it up and discovered fuel leak in fuel lines toward back of engine bay ( nearest front of car). Lines were brittle through age I assume.
Can anyone help with sizes outside diameter and inside diameter. Also what type of fuel line should I use
lones are towards the back left side of photo.
Old 03-03-2018, 10:18 AM
You will hear this time and time again here, reach out to boxstergt (Len) and he will get you set up with everything you could need and of the highest quality.
1982 911 Targa, 3.0L ROW with Webers
Old 03-03-2018, 10:30 AM
Bollweevil
This is a good place to start.. ^^^^ assuming your fuel lines are all original, you should seriously consider replacing ALL of them, from the fuel tank to the engine compartment then all those in the engine compartment. The plastic fuel lines which run through the tunnel from the fuel tank to the engine compartment are particularly problematic as they are probably also brittle and if they start leaking ?? bad news.
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 03-03-2018, 10:53 AM
Yes, I'm beginning to get the picture. I just need to identify them all somehow, is there somewhere I can look this up��
Old 03-03-2018, 02:24 PM
lightbulb8817's Avatar
i would take some calipers to the various fittings and draw up a sketch.
Eric at BAT/Mocal is also very helpful with fittings and fuel/oil lines. he made the lines i needed the same day and i received them in the mail about 2 days later.
Old 03-03-2018, 02:56 PM
Thanks,
Although my targa is originally from California, I am in the Uk and shipping is very expensive from USA, so looking to source nearer home.
Old 03-03-2018, 03:07 PM
evan9eleven's Avatar
Originally Posted by Littleeagle28 View Post
Thanks,
Reality check. Shipping is peanuts compared to the hassle of sourcing everything yourself, or your car catching fire. Len (BoxsterGT) is your guy, you'll get bespoke lines of highest quality. the lines themselves aren't cheap but the shipping is just a fraction. I just replaced mine with new lines from Len, highly recommended.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 03-03-2018, 03:15 PM
Gotcha, how do I contact him?
Old 03-03-2018, 05:15 PM
steely's Avatar
Go here for a parts list - you will have to download the PET catalog as a PDF.
https://www.porsche.com/usa/accessoriesandservices/porscheservice/serviceandorgininalparts/originalparts/
Go to the fuel section 2 and browse - you should be able to buy decent fuel lines in bulk and cut to length yourself. Search here in pelican for the nice recommended clamp, I don't know the brand. Don't get Oeticker clamps unless you want to buy the tool.
in many cases, the line diameter is described in the parts list - or you can measure yours.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 03-03-2018, 05:49 PM
HarryD's Avatar
Reach out to BoxsterGT. He may be able to help you out.
Some interesting reading:
Anyone Know CIS Hard Fuel Line Sizes - the black plastic type
CIS Fuel Line Fitting & Refurbishing Services
CIS Fuel Lines
CIS fuel line (leak/replacement)
CIS Plastic Fuel Line replacement?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-03-2018, 09:35 PM
Thanks.
Old 03-04-2018, 03:26 AM
how do i contact you please
Old 03-04-2018, 05:02 AM
Hi,you can pm me if you like, if you do not want to write here.
Old 03-04-2018, 06:32 AM
len.cummings (at) verizon.net
He doesn't read PM's.
2004 Boxster S
Old 03-04-2018, 02:03 PM
Thanks, we have now been in contact.
Old 03-04-2018, 02:27 PM
BoxsterGT's Avatar
Porsche Crest
Don't know if we have spoken littleeagle28, but here are a pair of original 74 tunnel lines vs my Polyamide replacements......
The original White Nylon Tunnel tubes turn Brown (Inner in photos) and brittle, and will crack at the slightest disturbance.
The Black Polyamide tube (Outer in photos) has been used since 1976 by Porsche and so far seems to be bulletproof. This same type of tube is now used worldwide by most auto manufacturers.
Len at Autosportengineering dot com
Old 03-11-2018, 12:34 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Can't say enough about Len, he is your go-to guy for proper fuel line replacements. Been a while but I believe I replaced all the engine compartment lines on my 3.2 race car with his SS line set, excellent quality and value..
Gary R.
Old 03-11-2018, 05:38 AM
Rouxzy's Avatar
Len's product is the best. Just got around to installing the set I bought off him and they are top shelf. He also send you a part to connect the old line to the new ones so that you can pull out the old line with the new one following it. Without this the replacement is very very painful.
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 03-11-2018, 05:46 AM
BoxsterGT's Avatar
Porsche Crest
To those who have been trying to reach me at my Autosport address, my apologies.
I am having trouble with this address and have moved over to my Verizon account.
Please try len dot cummings at verizon dot net.
This one seems to work properly. Thank you Pelicans all.
Len
Old 04-02-2018, 02:36 PM
Update:
Replaced a lot of fuel lines in the engine bay, as most crumbled to dust when I manhandled them. Will get the ones running under the car from len later, as I am currently using an IV straight into the fuel pump at the moment.
So tried starting again, no leaks, but no joy with starting either.
Tried playing with the flap in the air box/ fuel distributer, I suspect the 'plunger' in the fuel mixer is stuck in the up position.
Does anyone know how to remove the mixer top from the engine, so as to try and loosen the plunger.
Thanks all.
Old 04-03-2018, 10:06 AM
