jamesjedi's Avatar
Shipping Cylinder Heads?
Any creative ideas to ship heads ?
Thanks for any insight.
Old 11-16-2018, 01:11 PM
I and others have made an “H” of plywood and bolted the heads together with long bolts through the plywood.
Rutager West
Old 11-16-2018, 01:18 PM
jamesjedi's Avatar
Thanks for responding.
I must be missing something - the H lets you bolt the top and bottom with a middle divider?
Old 11-16-2018, 01:29 PM
Once a friend of Cliff
juanbenae's Avatar
roll them in cardboard with enough of it hanging over the edges to fold them over and tape the heck out of them encapsulating them completely. kinda like wrapping a present. then pack in a big box with standard cushioning for heavy parts.
Old 11-16-2018, 03:29 PM
gtc gtc is offline
abides.
gtc's Avatar
How my heads came back from cgarr:
1 piece of plywood, three heads on each side with combustion chambers facing the wood, each pair of heads bolted together through the plywood with some long bolts.
Then place in well padded box as a unit.
Graham
1984 Carrera Targa
Old 11-16-2018, 03:46 PM
Here’s an “artist” rendering of how it’s done- sides protect and hold upright in box and heads get bolted to the middle face to face. Make the wood tall enough to protect intake and exhaust studs.
When cgarr returned mine, he just individually wrapped and boxed each one in perfectly sized boxes then placed in another cardboard box to ship.
Rutager West
Old 11-16-2018, 05:59 PM
jamesjedi's Avatar
Great suggestions. Thanks
Old 11-16-2018, 07:42 PM
911tracker85's Avatar
I have mine bolted to a piece of plywood that will go into a double sided cardboard box. another peice of plywood on top to protect them.
will be shipping my heads and case to Steve Weiner at Rennsport systems soon.
good luck on your build.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 11-17-2018, 06:56 AM
The most important thing is to protect the machined surfaces from the studs on the other heads.
Rutager West
Old 11-17-2018, 03:15 PM
Bill Douglas's Avatar
So where and what's happening to the heads?
Old 11-17-2018, 03:22 PM
jamesjedi's Avatar
Thanks for the replies.
I am still determining where they will be sent.
I am leaning towards Cgarr? He has positive feedback, and priced well. I have tried the local guy but have not heard back from him.
Old 11-17-2018, 03:39 PM
Earthling
Brian Cameron's Avatar
When i shipped my 993 heads to Steve that was exactly how he told me to ship them.
Mounted on the plywood board:
Boxed up and ready to close & ship:
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 11-18-2018, 08:24 PM
I have been waiting for a few months to send my stuff to Steve. they were just overwhelmed with work in prep for rennsport. I also need to finish boxing/protecting the case to ship too.
Bob Cox
Old 11-19-2018, 07:13 AM
jamesjedi's Avatar
I have just about finished the H pattern for shipping the heads. Do I have to use shouldered bolts? Or can I use a bolt that is threaded through the head? I am concerned of the possibility for damage due to the threaded portion being in contact with the head?
Old 03-13-2019, 03:10 PM
Earthling
I just used regular bolts with washers at the head and nut ends. Tighten them enough that they won’t bounce around in transit and that will prevent the inside of the holes for the head bolts from getting marred. No need to torque them to extremes.
The critical place to avoid marring is on the bottom where the heads marry with the cylinders, if you’re mounting on a wood panel it should be soft enough but if you’re an overachiever you could put some foam wrap or scraps of cloth between the heads and panel before you bolt down.
Old 03-13-2019, 04:17 PM
jamesjedi's Avatar
Ok thanks. They are bolted together with non-shoulder bolts.
Old 03-13-2019, 04:48 PM
T77911S's Avatar
i am more worried about bending my loooong intake studs on my 930.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-14-2019, 10:21 AM
Pull the stude, just double nut them out
Bruce
Old 03-14-2019, 06:15 PM
When Ollies sent mine back they were each in their own individual box inside a bigger box.
Tom Feeney
1970 911 T
1973 911 T
Looking for engine 6103643
Old 03-14-2019, 06:20 PM
jamesjedi's Avatar
It takes more (much more) time than you would think to make the box. Get plywood, find bolts that are the correct length, and build it to fit a box.
Makes me think that rolling them in cardboard may have been easier.
Old 03-14-2019, 07:17 PM
