73 911T help!
Ok so I bought my first Porsche!!! Super happy!! Well not so happy as it doesn’t start!
The problem is it has no spark, I know this is a normal question but everywhere I look for help it talks about the cdi ! My engine has no cdi installed, it’s should be strat forward you would think! Coil, distribrater and sparkplugs! Well I changed the coil the points the condenser! Still no spark! I have power going into the coil on the + poll, I have spark at the points when I open them with a screwdriver, but no spark at the plugs! Please help I am super excited to take this girl out!!!
Old 03-21-2019, 04:35 AM
Hellraiser's Avatar
Send a message via MSN to Hellraiser
Rotor/ distr. Cap?
Old 03-21-2019, 05:16 AM
All new!!
Old 03-21-2019, 05:32 AM
Sounds as if your points need to be checked for a gap, they might not be opening.
I had a nice '73 T. You're a lucky man.
Old 03-21-2019, 05:46 AM
Ok after going over what had been done I noticed the points not opening! They are new and faulty as the plastic tip that opens and closes the pounds was broken! Ran to the shop got some new ones and I now have spark again!!!! Still not firing so I’m doing the timing now as I know the dizzy was out! Cross fingers! And tips on setting up the timing would be much appreciated
Old 03-21-2019, 06:19 AM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Wayne's engine book
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 03-21-2019, 09:51 AM
Below is timing for 1973, 1974, 1975, and 1976. All should be the same. You can set "Static timing" before starting the engine.
A common error is to get the distributor "180 deg out". That is, the crankshaft points to TDC (Z1) twice for a single rotation of the distributor. To ensure that you are on the correct TDC, remove the upper left hand valve cover, and make sure that the intake rocker for cylinder #1 is loose. If you are on TDC where #4 should be firing (180 deg out), the intake rocker for #1 will already be starting to open the valve, and the rocker will be tight.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 03-21-2019, 11:09 AM
(man/dude)
Jonny042's Avatar
If you have no cdi that could be the issue..... EDIT Ooops. I see you have spark. Never mind.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 03-21-2019, 01:23 PM
If you want it to run decently you need a cd box
Old 03-21-2019, 09:10 PM
Ok thank you everyone!!! Great advice! I got her going just as the sun started coming out over here in cold Sweden! At first I didn’t but thanks for the reminder from walter_middle I had the timing 180 ass about!!! Thank you all again
Old 03-22-2019, 06:09 AM
E Sully's Avatar
AS stated, if you are running a basic coil and points, the car will run, but you will not get a good spark to run well. The original coil, points, condenser, spark plugs were designed to work with the CDI box. To get good performance, you will need to run the original CDI, or a good aftermarket ignition.
MSD setups seem to be an option to the original CDI, as well as Street Fire.
https://forums.pelicanparts.com/porsche-911-technical-forum/1024210-msd-setup-my-new-3-2-ss-build.html
Ed
1973.5 T
Old 03-22-2019, 06:48 AM
Tags
no cdi , no spark
