Alternator ID - Bosch or Marchel?
I have a 3.0 engine from a 1978 SC I’m putting in my 70 911E. I’m trying to figure out what voltage regulator I need to buy. I gather it has to be matched to one of the two alternator types used. Problem is, there’s no identifying label or stamp or anything apparent on the alternator, and I have no idea how to tell the two apart.
Any ideas on what I have and what the visual differences are? Thanks, Bob
Looks like Marchal
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
RETIRED
Looks like it surrendered....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Still here
Decide if you want it outside or inside.
The latter was an upgrade per Porsche. https://forums.pelicanparts.com/porsche-911-technical-forum/849187-alternator-w-external-regulator-convert-internal-regulator.html#post8461133 |
It's a 70 amp Marchal alternator.
Dave |
Good to know. Thanks very much. Now I just have to figure out how to get it out of the fan housing to tidy it all up.
Cheers |
Tap the housing on a block of wood a few times all the way around. The alt will fall out.
Dave |
2 wood blocks with enough clearance (2x4) to allow the alternator to continue to drop after the housing is dropped against the wood blocks. Sometimes totakes several drops.
Bruce |
