Edunit
911 Rennaire conversion query
I'm looking at the two footwell fan units OE and Rennaire. The Rennaire seems to have the large slot in the edge of the housing in the wrong place? Bear in mind they are both the same way up
Old 04-26-2020, 07:38 AM
That's a bit odd Ed!
Assuming your car is RHD, it will make wiring to the fan speed switch a little more direct but may require you to lengthen the earth lead if you intend to use the existing condenser mounting stud on the floor of the car.
This photo, right way up, may help you.
Old 04-27-2020, 01:30 AM
Edunit
Thank you for that Peter
Old 04-28-2020, 10:32 AM
