987 Frunk demon lockout
Hi
I am stuck. Frunk does not open with either key fob or interior switch activation. Rear trunk works with ether. Battery is fine, car starts and runs. I can hear the actuator cycle with either key fob or interior switch activation. Tried to raise Frunk with large suction cups while cycling - no joy. Tried pushing down - no joy. Seems like there should be a spring pushing up on the lid but it lays flat. Seems like the manual opener is not a good option. Opinions, thoughts? Thank you all, Howard Have subsequently pulled emergency cable. Came out 18 inches. Not connected internally. A What is best way in, hood or bumper, or? Hg |
You should try posting on the Boxter/Caymen forum for help on this. Also, do a search there and see what comes up.
https://forums.pelicanparts.com/boxster-cayman-forum/ There is supposed to be a spring that pushes up the lid. Also surprised on the emergency release not being connected.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
is the emergency cable you pulled the one in the driver side front wheelwell? you may need to remove the wheel for access..
Solenoid is being activated normally. |
disband
wrong hole.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
