jamesjedi's Avatar
A Very Small Scratch in Alusil Piston
Hi,
I made a very small scratch in one alusil piston while trying to remove a stubborn clip. Would it be recommended to file or sand it down enough to make it unnoticeable to the touch? These pistons look perfect otherwise.
I know it would be great to get CP pistons and replate, however I would like to use these pistons.
James
Old 03-27-2019, 05:37 AM
I wouldn't worry about it. The rings are touching the cylinder wall the piston does not make contact with the cylinder wall. Maybe use some emery cloth on the scratch.
Old 03-27-2019, 06:34 AM
DSS Racing actually cuts grooves in the piston skirts.
Some hypothesis about carbon deposits having room to escape without damaging the cylinder walls.
Anyway I wouldn't worry about a scratch.
Derrick
Old 03-27-2019, 06:40 AM
I would burnish it out, just don't make it deeper.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 03-27-2019, 09:44 AM
jamesjedi's Avatar
Ok Thanks for the replies. I was vary disappointed in myself for making the mark. I will try to remove the edge.
Thanks again
James
Old 03-27-2019, 10:54 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Just use something like 220/320 wet sanding paper and your finger tip with water. Don't over work it.
When I did the top end on my 81 in the 90's, there was a vertical score on one of the alusil pistons. Something got in there. Piece of carbon?
It was not huge but it was definitely there.
I did not touch it as it went right back in where it came out. Doing fine 22 years later.
1981 911SC Targa
Old 03-27-2019, 03:07 PM
jamesjedi's Avatar
Thanks Bob.
Old 03-27-2019, 04:38 PM
Don’t mess with it. The aluminum piston is softer than the cylinder wall. The scratch won’t matter. If you try to “fix “ it, you’ll remove the ferrous coating on the piston. That coating is there too keep the pistons from “gauling “ with the aluminum cylinders.
Old 03-27-2019, 11:56 PM
