7783911's Avatar
Aero Mirror Loose
The glass portion of my psgr Aero style mirror is not "tight" and after any sprited driving the mirror position will have moved from vibrations/bumps. I took it apart and cant for my life see any way to make the glass mounting any snugger
any suggestions?
Old 02-21-2019, 06:13 PM
7783911's Avatar
BUMP..someone must have some ideas?
Old 03-05-2019, 09:23 AM
You have the notched ring all the way over ?
If nothings broken back there that’s the only thing I can think of .
4 clicks to remove glass , and 4 to lock it in iirc .
Will check after work if you like ?
Old 03-05-2019, 12:18 PM
7783911's Avatar
Yes, I tried that, even took the mirror apart to see what creates the friction point but had no luck there. sigh
Old 03-05-2019, 12:57 PM
My drivers side is apart at the moment if I can help with photos??
Unfortunately even a low speed drive is out of the question right now , but I do have an old glass removed from car and a new genuine one in box ready to install so can take pics to compare with what I have .
I’ve had 2 mirror glasses mysteriously fall off Porsche’s in the past two months or so.
Adhesive failure holding glass to backing.
Saw the boxster glass peel itself loose in slow motion as I shut the door and managed to catch it then super glue it back on , 964 no such luck ....
It was there , then it wasn’t .
I can look , but think it was $150 for a new heated glass .
Old 03-05-2019, 09:57 PM
7783911's Avatar
the notched ring is tight..so not sure what to do next
Old 03-26-2019, 05:37 PM
MConn's Avatar
If the mirrors are manual, a metal ring puts pressure on the pivot ball -
If the mirrors are power -
I think you have to get a motor assembly. I took one of the motor assemblies apart several years ago, and it seems that there is a ty-rap looking rack inside that fails.
Mike
The more I learn, the less I know.
Old 03-27-2019, 10:12 PM
