yayo_ayala's Avatar
Question about the Blower
My lates project is to fix the blower, I already bought the motor. When I opened the housing I saw the rubbers/seals and they are very old. is it possible to buy them? or which material can I use to rebuild it?
thanks
Old 03-19-2019, 07:15 PM
Synchro Joe's Avatar
I recently had mine apart and found the same thing, probably original stuff. I could not find a source for OEM replacement stuff, so used very thin foam insulation with the sticky backing and also added some industrial strength glue to be sure. Cured it overnight and ran a bench test with 12V power supply before installing. You can normally find the foam in rolls in hardware store and perhaps auto supply stores.
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 03-19-2019, 09:26 PM
AutoBahned
RWebb's Avatar
yes, thin foam - thin wetsuit material is even better
oil the motor while it's out
clean all the crap out of the ducting
be very careful with those spring clips - eye protection and a sparse area to search for the ones that pop away from you - use a rod above them ot catch them...
Old 03-20-2019, 01:41 PM
yayo_ayala's Avatar
Thanks guys, this weekend I will try to fix i. I really appreciate your inputs, and the people who email me directly.
Someone sent me the following link for neoprene washers:
https://www.ebay.com/itm/Large-Diameter-Fender-Washers-Neoprene-Rubber-Fender-Washers/264221526186
Old 03-21-2019, 08:25 AM
the replacement parts already cut to the correct size can be ordered at 914rubber.com. I also replaced my fan blower housing seal which had also deteriorated. they sell that also. very reasonable
Old 03-21-2019, 02:11 PM
911T70's Avatar
What are the odds - I just finished replacing the seals! Couldn't find suitable rubber foam so I bought a 4mm sheet of neoprene rubber and cut the seals. Because the rubber is rather hard, I was able to sand it down to fit perfectly, rounding off the edges so that they don't impede rotation.
Michel
1970 911T
Old 03-21-2019, 04:26 PM
yayo_ayala's Avatar
Thanks John they have exactly the part that I am looking:
https://900designs-container.zoeysite.com/flapper-valve-seals-in-blower-housing-1
Hi Michael your blower looks amazing.
Old 03-23-2019, 09:12 PM
yayo_ayala's Avatar
Thanks to everybody, I just finished the job. Now i have to figure out how much that cable run 😉. I do not know in th dashboard the upper right control (the cable that opens the blower) how much should it open.
Old 03-30-2019, 10:33 PM
