Narrowest 2post lift
Wife wants to park her car in garage in winter time(imagine that!). Have a garage that has a useable footprint of 19w and 20L and 12.4 h. Have 8" slab. Any ideas what is the narrowest 2 post lift is to give my wife ample room to park. How close to the outside wall can be the post be mounted? Seen anywhere from 6" to 2 ft. Thanks Jerry
Old 03-02-2018, 06:05 AM
My Rotary brand lift (highly recommended) is adjustable width - I'm sure it could be modified to a width that is unusable for lifting anything other than old MG's.
There is a hydraulic release you'll need clearance for, but otherwise I'm sure 6" is plenty. I have mine a little more than 12", and it's tight but you can get around it (very handy so you don't have to walk around).
Good luck, hope you can work it out - it still is one of the best investments I've ever made.
Chuck.H
'89 TurboLookTarga, 438k miles
Old 03-02-2018, 07:35 AM
old man neri's Avatar
Plenty of lifts out there that are stand alone, that is to say, have no connection between the two posts. They can be as narrow apart and as far apart as you wish. The car and the hoist arms will determine how narrow it can be.
How far from the wall varies as well. The manufacturer will probably have a recommendation as to have far from the edge of the slab it should be. If your garage has footings or a monolithic slab will probably affect that answer as well. Another thing to consider is what can you do if the post is right up against the wall. If it's 6" away from the wall and the posts set really close together could mean the car would be very close to the wall. Do you really want to work on brakes/suspension when the car is only 18" from a wall? Think you can get a torsion bar out when it's that close? Something to think about.
A good place for information is garagejournal.com
Old 03-02-2018, 08:33 AM
Send a message via Yahoo to Lukesportsman
If things get tough on space and keeping both sides happy, have you considered this?
https://www.maxjaxusa.com/
https://www.homedepot.com/p/Dannmar-MaxJax-2-Post-Portable-Lift-DMJ-6/204163445
OR
https://www.bestbuyautoequipment.com/6k-low-profile-single-mobile-column-lift-p/AL-MSC-6KLP.htm?gclid=Cj0KCQiAieTUBRCaARIsAHeLDCRoL31oeyO JT8mCOpIvcOKW2Rk4V8rODBcuqkcm9toBMXNh5FQbNSoaAnENE ALw_wcB
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 03-02-2018, 12:03 PM
I also have one of these, but my P cars won't clear. Depends on what she drives as a stock SUV/truck would have no issue. It's not as useful as a two post, but serves a purpose in basement garage. STILL, so much better than jack stands all the time.
Luke S.
Old 03-02-2018, 12:08 PM
Cars and Cappuccino
tdw28210's Avatar
Get a single column, but not the "mobile" version. Unless you need mobile.
https://www.naautoequipment.com/Atlas-SP6000-Single-Post-Lift-p/tp-xl-sp6000-.htm
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 03-02-2018, 01:29 PM
Are you talking about the spacing between them?
Usually you can space them apart any amount you want.
As for how close to the outside wall, you can butt it up as close as you can (as long as the controls are on the other side).
1987 Porsche 911 Carrera Coupe
Old 03-02-2018, 01:57 PM
Thanks for all the suggestions, If I cant find a 2 post lift that works I like the idea o single post lifts. Just move it to the outside wall and possibly have some floor brackets fabricated and bolt it to the floor. It does not have to be mobile. Also, I have to look closer at the baseplate 2 posts The Atlas unit has ramps which I don't prefer. Thanks again,
Old 03-02-2018, 02:35 PM
Cars and Cappuccino
tdw28210's Avatar
Just wondering. Is an in-ground single post an option? About as out-of-the-way a permanent lift can get.
Old 03-02-2018, 02:52 PM
Robind's Avatar
Really happy with our single post lift, more than adequate for the job and saves loads of room
Fixing the broken bits in the garage or ragging around the track
Old 03-03-2018, 07:42 AM
What sorcery is this?
A one post lift? Brilliant, who is the manufacturer.
Old 03-03-2018, 08:37 AM
Platinum Member
dad911's Avatar
I think most lift mfg have 1 posts now. I have eagle 2 post and 4 post, here is their 1 post:
https://www.eagleequip.com/category/specialty-lifts.html
Have you considered a 4 post? Easy drive-on, still good for most jobs.
Old 03-03-2018, 08:43 AM
joegt3cup's Avatar
It would be great if someone offered a single post with attachable/detachable ramps so the wheels aren't suspended when used for storage.
Joe
Old 03-03-2018, 09:09 AM
Really liking the idea of the single post lift esp for our 2700 lb Porsches. Anyone recommend a particular brand. Called Eagle yesterday to get a shipping price, the sales person was very helpful. Challenger has a 2 post LE-10 that is a little narrower than most .
Old 03-03-2018, 10:10 AM
Robind's Avatar
Automotech Services Limited - Specialists in Vehicle Lifts and Garage Equipment
This is Euro supplier but must be a US supplier, a friend has the mobile version and this works really well
Old 03-03-2018, 11:07 PM
when shopping keep in mind “lift height” talks about the car, not the clearance underneath. Those arms can be thick
Also the suspension sags and wheels hang low when lifted so don’tt think 6 ft lift=6 foot clearance undernearh
Old 03-04-2018, 03:27 AM
https://www.elevatorauto.ro/
Old 03-31-2019, 09:20 AM
