-   -   Flywheel question. Re install or new? 1 tooth missing. (http://forums.pelicanparts.com/porsche-911-technical-forum/1025311-flywheel-question-re-install-new-1-tooth-missing.html)
camdon 04-01-2019 11:08 AM
Putting the motor back in my 964. It never had and issue with starting. Just noticed the flywheel is missing 1 tooth.
reinstall it or get a new one?(if I can even find one)
Thanks guys
gomezoneill 04-01-2019 03:56 PM
You know the answer.
smadsen 04-01-2019 04:24 PM
I don't know about Porsche or the 964 specifically, but generally the ring gear is removable and replaceable on the flywheel on most cars in my experience.
cabmandone 04-01-2019 04:30 PM
Depends. How much do you drive it? Do you mind taking it back apart when, not if, it fails?
Bill Douglas 04-01-2019 04:31 PM
Let's say the next tooth goes missing too...
964TargaC2 04-02-2019 01:33 AM
yes the ring gear is removable and replaceable on the 964
proporsche 04-02-2019 02:09 AM
do not think twice ,it is around 140 bucks here is your part number
964.114.143.02
Ivan
smokintr6 04-02-2019 08:56 AM
Not to be silly, but since you mentioned that the car started fine: You know there are two sets of "teeth" and one of the sets of teeth is supposed to have one missing to trip the flywheel sensor. Is the starter gear missing a tooth, or is the trigger wheel missing a tooth? One is a big problem, the other is exactly as it should be.
pampadori 04-02-2019 08:58 AM
These are as they should be:
https://www.pelicanparts.com/catalog...401202-M37.jpg
https://www.pelicanparts.com/catalog...-M894-Pic2.jpg
Targa Me 04-02-2019 08:59 AM
No brainer. Replace it.
Marc Bixen 04-02-2019 09:00 AM
smokntr6, Exactly my thoughts.
85911 04-02-2019 10:11 AM
Put the flywheel sans ring gear in the freezer. When frozen, heat up the ring gear with a flame or the oven. When hot, it will drop onto the cold flywheel.
camdon 04-02-2019 10:29 AM
Best place to purchase a new one? Porsche said 1400.00
Flat6pac 04-02-2019 10:36 AM
Check the picture, smokin6 has the flywheel answer and Pamp picture shows the missing tooth on the motronic flywheel
Bruce
camdon 04-02-2019 10:58 AM
Here is it. I guess I need to find a new one for the best price. Any sponsors here?http://forums.pelicanparts.com/uploa...1554227817.jpg
proporsche 04-02-2019 11:05 AM
again why not new 140 Bucks is not much,or?
Ivan
camdon 04-02-2019 11:07 AM
Originally Posted by proporsche (Post 10413766)
again why not new 140 bucks is not much,or?
Ivan
1400.00
proporsche 04-02-2019 11:12 AM
did i say 1400 i have written 140 bucks ,mama mia ,above is a part number and check it with pel.parts
Ivan
proporsche 04-02-2019 11:42 AM
here is one on ebay for 150 ...here is the number
401492380636
brcorp 04-02-2019 11:48 AM
When you get stranded it won't be in your driveway or even close to home.....
