Stand alone ECU options for a 3.2
I'm planning to fit a stand alone ECU and harness for my 3.2 engine swap, the reason is to be able to tune it more easily (already got a got a good EFI tuning background, mainly with Holley and HP Tuners) and to be able to diagnose any fault that may occur, plus its good to have a closed-loop engine management. So for the guys who already did it, what kit did you use? and what are the options that I can choose from? I already heard about VEMS, but would like to know about other options as well.
Old 04-07-2019, 02:49 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Megasquirt2 has worked out well for me. I purchased it in kit form from DIYautotune and it is also offered in fully assembled versions. For the crank trigger, Goingsuperfast offers pulleys and trigger holders at a reasonable price.
1986 Targa Guards Red
2021 MT09 SP
Old 04-07-2019, 03:38 PM
Turbonut
Raceboy's Avatar
VEMS is the only one that is plug and play afaik. Meaning you can retain original engine harness and not cutting anything etc. Comes with integrated wideband also.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet
http://www.facebook.com/vemsporsche
Old 04-07-2019, 08:56 PM
To my knowledge the only directly interchangeable ECU for the 3.2 Carrera, is Canems in the UK. The swap is literally done in 2 minutes. Unplug the old Motronic, and plug in the new Canems ECU. Start and go. Then you can start to play with it, and do whatever you want. You can do twin plug, you can do ITB, wide band lambda, coil packs, bigger cams, other injectors, skip the ICV, do MAF or MAP sensors, the list is endless. And you can do one little thing at a time. And have data logging and diagnostics, that the old Motronic never had.
No affiliation...
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 04-10-2019, 11:02 AM
Turbonut
Raceboy's Avatar
VEMS is the same with only difference that VEMS uses proper TPS and built in wideband lambda. Everything is plug and play, no need to cut wires and is easily reversible.
Old 04-10-2019, 12:52 PM
I set myself and ordered a VEMS kit. Waiting for the delivery and I will post some pics of the install will tell you how it will go.
Old 04-10-2019, 09:34 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Hello,
I have the DME Shop afm, will your ECU work with that?
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-10-2019, 11:10 PM
Turbonut
Raceboy's Avatar
VEMS does not use AFM, it uses built-in MAP sensor. Kit comes with short adapter wire that is used to connect air temp sensor to AFM connector.
Old 04-11-2019, 04:22 AM
Similar to this:
911 Vitesse MAF Kits
I incorrectly used AFM, instead MAF. The problem with the AFM is they are all used, so even "repairing" them is only working on used parts. The MAF is the logical extension into the future for cars that are staying closer to stock.
Old 04-11-2019, 08:57 AM
Turbonut
Raceboy's Avatar
MAP sensor with closed loop wideband lambda will have better tunability and makes it possible to use ITB's, turbocharger, supercharge etc. There is no issues with intake pulsations like with MAF when using wild cams and/or ITB's.
Plus most kits still use ancient idle/wot switch not proper TPS which really hurts throttle response.
Old 04-11-2019, 11:18 AM
