Gasket?
My 75 911s has slow oil licking at fitting at to reservoir from returning line from oil cooler front of the car. Was there any gasket goes in the fitting to the reservoir? If so where can I buy the gasket?
Old 04-01-2019, 12:49 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Hienz - if you'd like to send me a PM with your email address, I will have one of our Porsche reps. get in touch with you and assist with the gasket for your '75. Thanks.
Old 04-01-2019, 01:13 PM
Registered Minimalist
75 911s's Avatar
No gasket within the mouth of the oil fitting if that's what you mean. Those lines get old. They are pretty inexpensive to replace if you go with the off brand.
It sounds like someone added a front cooler, so make that distinction if you do order parts because there are different lines obviously.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 04-01-2019, 02:02 PM
Hi Dmitry
Please email me at hienz964@yahoo.com
Old 04-01-2019, 03:38 PM
Administrator
Originally Posted by hienz View Post
Hi Dmitry
Thanks - forwarding this now. You should have an email from us tomorrow AM.
Old 04-01-2019, 03:43 PM
If oil is leaking somewhere along the rubber hose, then I can assume the lines get old. But
Mine is leaking at the fitting to the oil reservoir, and when tightening the fitting nut oil reduced dripping out
Old 04-01-2019, 03:50 PM
Dmitry,
Old 04-01-2019, 03:51 PM
