-   -   Dry ice vs factory floor tar (http://forums.pelicanparts.com/porsche-911-technical-forum/1025391-dry-ice-vs-factory-floor-tar.html)
911tracker85 04-03-2019 05:28 AM
I am still struggling with how much sound deadening to reinstall. this is not being built to be a quiet, comfy cruiser but a harsh, loud track capable beast. even though most driving will be on the street to events, car shows, and for an occasional adrenaline rush.
75 911s 04-03-2019 05:29 AM
If you transport Dry ice inside your car, roll the windows down.
I did the heat gun method and it worked awesome. I had one side done in the time it would take to go buy dry ice, bring it back, spread it etc. If you use a plastic paint scraper with the heat gun, it comes up like hard taffy and leaves a clean surface. It can come up in large chunks if you spread the heat as you work the plastic scraper under.
<iframe width="560" height="315" src="https://www.youtube.com/embed/tB00z3MTTS0" frameborder="0" allow="accelerometer;encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
1979-930 04-03-2019 06:39 AM
I'm getting ready to start a similar build. I'm not doing any in the floors, doors, roof, ect. I figure I can add those areas later if it's too loud.
I am going to line the rear parcel with some Mass loaded vinyl to take some of the harsh frequencies out of the engine noise. The stuff is heavy but provides the best noise canceling per lb. I haven't decided if I want to put it inside or in a Singer style engine pad.
911tracker85 04-04-2019 07:12 AM
OK... I'll try the heat gun and knife first.
will do this before we bead blast the tub. I did not want to try to get that stuff off with bead blasting.
wish me luck.
JmuRiz 04-10-2019 06:51 AM
Originally Posted by Flojo (Post 10414696)
heat gun and scraper...
+1 o the Flojo method....it's a pain in the butt and takes a while, but it works.
BTW Flojo, what paint did you use on the floors? My 914s are stripped, just going back/forth on what to paint with.
