Turn Signals
Perhaps I can get some help with this:
Left hand turn signals work fine. The emergency flashers work on the left side only. Right hand the signal lights come on but do not blink, however the blinking sound does. All bulbs have been replaced with new. Any help appreciated. |
I had the same issues on my car. Turned out it was the ground adjacent to the light housing needed to be cleaned very well and then reinstalled. I cleaned both body and wire eyelets and installed dielectric grease.
Give it a shot.
Jeff 1982 911SC 1973 TR6 1979 124 Spider 1978 124 Spider |
Thank you I’ll try that
New-ish 911SC Targa Owner
CHeck that your two-filiment bulbs (like the rear brake/parking light bulbs) aren't installed 180 degrees off. That gave my car some unusual lighting outcomes where lights that weren't even in that circuit would flash. I was about to light a bundle of sage and try to exercise the demons out of the car when i checked them again and found the issue.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Recreational User
Yes, check proper bulb contacts and grounds.
