Engine mounts - M8 side bolts
Are there any tricks to removing the 2 M8 bolts that fix each engine mount in place? I can’t find anything specific to these bolts (lots on the M12s). How do you get a wrench on the nut below?
Thanks.
Old 03-29-2019, 07:02 PM
Nobody has battled these little demons?
Old 03-30-2019, 08:38 AM
pete3799's Avatar
I have but can't remember what i used to get to them.
On reassembly I seem to remember having to put a dab of grease on a finger, stick nut on finger, and reach under then thread bolt onto the nut.
Pete
79 911SC RoW
Old 03-30-2019, 09:35 AM
Functionista
manbridge 74's Avatar
Did this recently, I think I used a small box end wrench or swivel head wrench to jam the nut as I tuned bolt above. Taped the box wrench on one side to hold nut when re-installling.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-30-2019, 09:59 AM
What model year car?
Thanks.
OldSpool,
I used a 13-mm sockets for both top and bottom nuts. The key is having a flex ratchet for the bottom nut. Do you need to see what I used? Keep us posted.
Tony
Old 03-30-2019, 10:08 AM
Thanks all. It’s really the inboard ones that have such limited access. I have flex ratchets and ratcheting box wrenches and I can be stubborn so this should be the winning combo.
I’ll send along updates if useful for others.
Thanks again.
Will
Old 03-30-2019, 10:15 AM
Looks like dropping the engine slightly while keeping main M12s somewhat engaged might yield the needed clearance. More to come.
Old 03-30-2019, 11:18 AM
Done. Not too bad. Drop the engine slightly to make more room for ratcheting box wrench to grab nut on bottom end of M8. Torque and then jack back up, torque M12s.
Old 03-30-2019, 02:35 PM
I just used an smaller ratchet and it took a really long time with lots of scraped knuckles. Getting the new nuts started wasn't fun. Taped a magnet to my finger for the nuts, still wasn't fun. I also changed the hardware, something nicer from Belmetric. Washers on both sides, good grip length and self locking nuts..
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 03-30-2019, 02:59 PM
Dropping the engine 1-2 inches was the trick. All done and happy. Quick shout out to Clint at Rebel for fast shipping, responsiveness and great customer service.
Old 04-01-2019, 04:41 PM
I'm sure this will start a discussion. Your washers are on upside down! Concave should face away from the mount.
Old 04-02-2019, 06:38 AM
I just realized something. The new M12 bolts I sources are 90mm not 95mm. I drove the car and all seemed well. Will the 5mm difference be an issue?
Old 04-03-2019, 07:22 AM
So how exactly do the motor mount washers go?
Any consensus on this? Concave up or down....
1988 Carrera coupe
1966 250 Ducati
2021 VW Golf TSI
2014 Ninja 300
Old 04-03-2019, 09:51 AM
Believe Porsche put out a bulletin on this indicating concave up for compliant feel and down for firmer. I saw the bulletin recently on Pelican but can’t find it.
Old 04-03-2019, 09:55 AM
New-ish 911SC Targa Owner
pampadori's Avatar
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 04-03-2019, 11:13 AM
