Leather Experts - help needed
My car has the full leather interior option - and the rear shelf has bent itself upwards.
I don't know if this is from the leather tightening and pulling the lip of the rear shelf up, or if someone fitted it wrong and bent up the end and the leather tightened itself up in the sun.
Either way I have a shelf with a bend in the back that shouldn't be there.
You can see the kick up underneath
Observe this pic I stole from the classifieds, which shows a flat shelf (also leather covered)
Question for anyone knowledgeable in interior leather:
What would be the best way to bend the shelf back down again and (presumably) stretch the leather back out again? I really want to get the shelf sitting flat under the rear window seal again, instaed of sticking up like a black ducks beak. The shelf itself appears to be some type of plastic or fibreglass. Am I going to need a lot of heat and leave it under something heavy for a while?
Old 03-31-2019, 08:25 PM
Harpo's Avatar
One option would be to wet down the rear shelf then flatten it out between two boards and some cement blocks. The speakers would have to come out before attempting this
Old 03-31-2019, 09:03 PM
I'm not sure what the shelf is made from? I was expecting some type of wood product but it doesn't appear to be. There's also the issue of the leather which is currently stretched very tight. Even if I can get the board to go flat with some weight I think the leather is going to pull it back again.
Old 03-31-2019, 10:22 PM
Can you reinforce it by epoxying an aluminum tube to the underside of the shelf once you’ve flattened it back out?
Old 04-01-2019, 04:46 AM
4flyboy's Avatar
Looks to be a leather issue.
The leather dashes on period cars are famous for shrinking and distorting the dash around the center A/C vent.
If it were mine I'd condition the leather over a considerable period of time until it was supple again ....I wouldn't rush this. I'd lay a flat wood plank over the area and add some even weight....
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 04-01-2019, 04:53 AM
autobonrun's Avatar
That's what I'm thinking as well. Chances are the fiber board has formed a 'memory' at this point; probably from the moisture and heat. It's hard to tell if the curvature is from the leather or the particle board.
I would remove all the disintegrating material off the back and create some rib bracing to keep it flat. Use Liquid-Nails and some very strong metal bars at the correct spots on the back to keep it flat. I imagine the bars would need to be at least 1/2" x 1/2" to keep it flat over any distance. The problem will be can you place them at the appropriate spot and still be able to fasten it back down. I can't recall if there is metal underneath this shelf or not. If so, the 1/2" bar wouldn't work, you'd have to find something thinner but very strong to form a bracing.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 04-01-2019, 04:58 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I like this idea but I would use a long piece to 1/8" x2 " flat stock. Once in place there is little chance of it ever curling again..
Gary R.
Old 04-01-2019, 05:00 AM
I would replace it, remove leather and backing wet piece clamp it flat then trace it on to new material cut it out replace foam/ leather. Don't cob it up do it once do it right. A lot of heat back there.
Old 04-01-2019, 06:47 AM
I was thinking this but not sure if old leather will loosen up? I have chemical bros conditioner - might start putting that on frequently and see where I get
Old 04-01-2019, 06:56 AM
Doesnt this style parcel shelf sit on top of the rear window rubber seal?
1978 SC Targa
Old 04-01-2019, 07:13 AM
I had a similarly curled rear shelf. I tried detaching the leather to let it relax, used weights on the underlying material to flatten, and finally attached metal to hold it flat. None of this worked very well. The edge was still very uneven. My original plan was to get it close and then have it re-covered. I ended up buying a used shelf off ebay. So not saying it can't be done successfully but I failed.
1983SC RoW
Old 04-01-2019, 08:00 AM
Hmm that’s a bummer. Did the leather relax at all? Or once shrunk it was shrunk for good?
Old 04-01-2019, 08:06 AM
Leatherique. I've spent decades treating leather with various products - but since I used this for the first time, it's the only one I buy.
I bought some Sport seats intending to re-dye them to the color I wanted. Leather was hard as iron, totally inflexible. Driver's bolster was worn, cracked, scuffed up.
I started on the driver's seat as a control. Per Leatherique's instructions, before dying or dye prep, you treat the leather to get it in good condition.
By the time I got done feeding it 32oz (!!!! for one seat!!!) of Leatherique over a 4 week period (you can tell when its done; it won't accept any more product and little white crystals that look like salt come floating out of the leather), it was as soft as brand-new leather. Amazingly, all the scuffs and damage I'd thought was near-terminal had "healed" and looked way better.
I cleaned it and looked at it.
I simply couldn't bring myself to to take 600 grit to it; it went from an old looking seat to about as good as you would expect a 30 year old high-quality "driver" seat to be.
Sold the seats, bought some cores and had them re-covered the color i wanted. And treat them with Leatherique every year or two. They'll out-last me..
'77 S with '78 930 power and a few other things.
Old 04-01-2019, 08:08 AM
I used Obenauf's Leather Oil and can't claim the leather itself relaxed much but disconnecting it from the shelf allowed the shelf to flex more easily under weight. However, it really wanted to go back to its curled shape once the weights was removed. I was afraid to flex it the other direction too much to get the curl out as the material seemed like it would break or de-laminate. Your picture looks like a much smaller curl than mine had. The original owner (I am third) said a transport company left windows open allowing rain to get in and it ended up ruining the dash and rear shelf over time. It cost me quite a bit to find a used dashpad and rear shelf, and have both recovered in leather.
There are a series of staples holding the upper curved piece with the speaker holes to the lower piece that supports the rear passenger back rest. I carefully separated the two, had the curved piece off my ebay purchase recovered, and kept the original flat backrest piece as that leather was original and still in fine condition.
1983SC RoW
Old 04-01-2019, 08:46 AM
Thanks - I was hoping to keep the original leather as it is in good condition apart from the stretch. Dash has already been recovered so probably had the same issue. I’ll try some leather conditioning (maybe finally get some leatherique) and see if I can loosen it up.
I can’t work out if the leather pulled up the shelf or the shelf got put in wrong and leather adapted. Probably the leather pulled it up. There is no sign of water damage at all anywhere so I don’t think it got wet.
Old 04-01-2019, 11:31 AM
Couple of questions about using Leatherique, so posting here for anyone interested:
Just apply Rejuvenator until it won't take any more. Heat helps a lot at first to open up the leather - like treat, bag it up in a black plastic bin liner and leave in the sun. And time. It takes as long as it takes. It'll be obvious when you're done...
Keep re-applying (working it in with your hands works well at first, until the leather opens up). Re-apply whenever the leather looks matte/dry again. A seat may initially accept 2-3, even 4 or more applications a day. This will slow down, until eventually it just won't take anymore; even after several days the product just sits on the surface. And little white crystals may appear (that's the old salt/toxins/sweat etc, - apparently).
Then use Pristine Clean to remove the tacky. At this point, the leather will be really supple/soft.
Going forward, re-apply Rejuvenator/clean with Pristine Clean as necessary.
I used Neat's Foot Oil on bike jackets, boots, gloves for years - Leatherique is far better. I also use on my leather couch, tail, dash, door tops/cards etc.
Old 04-02-2019, 08:56 AM
Leather does shrink and get hard as it dries out, and relaxes and stretches when it's well-fed.
The cars weren't air tight to start with - and certainly are not once the foam in the rear roof vent crumbles to dust... So humidity in the air will get in, and if you're not driving it with the heat on to dry it out or keeping it in a climate-controlled storage area...
Based on my door cards, I think once that fiber board curls up (rain ingress for me), it could be tough to straighten it.
Might work to soak it thoroughly, maybe even steam it?, then clamp flat and let it dry out - but I'm just guessing.
Old 04-02-2019, 09:14 AM
I think working the leather until it is softer and then steaming the back is the way to go. I think I need to build a rig to put pressure on the board and then have steaming going on underneath - time and increasing pressure might work. I can see trying to brace it flat is probably doomed, but steaming might work.
Though I think long term I need a new top and new leather, but I might try repairing the old first.
Right now I have just put it back in because time is not on my side. I gave the leather a lot of conditioner but haven’t tried leatherique yet.
Old 04-02-2019, 09:50 AM
just a thought
make a new rear shelf
remove leather from original
treat it with leather conditioner to make is somewhat supple again
transfer the leather from the original board to the new board.
1981 930 euro
SOLD 1980 911 targa euro
Old 04-02-2019, 11:29 AM
Heck, I’m only 5 not 71!
targa80's Avatar
I would replace the warped hardback board with new and glue and staple the leather to it. I buy the /8 3x5 hardback board from home depot and have used it to replace the door inner boards and to stiffen up the sun visors. Also used same material to replace the driver side wooden floor board. I have posted several threads showing how i did it.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 04-03-2019, 04:34 AM
