-   -   915 Input Shaft Seal Installation in Guide Tube (http://forums.pelicanparts.com/porsche-911-technical-forum/1025597-915-input-shaft-seal-installation-guide-tube.html)
2jmotorsports 04-04-2019 06:44 AM
Dear Pelicans,
In which side should a new input shaft seal be pressed into a 915 guide tube? From the A side or B side indicated below?
http://forums.pelicanparts.com/uploa...1554388917.JPG
Gearbox is a 1983 915.
Also any other tips on installing the new seal? Install dry or lube?
Thanks in advance!
proporsche 04-04-2019 06:48 AM
Hi,i have a tool which is marked how deep the seal should go .I do it from the A side.Actually if look closely there is a end lip to which the seal should go to or ended up at...B full-arrow end on the pic...
Ivan
2jmotorsports 04-04-2019 07:25 AM
Hi Ivan,
I just removed my old guide tube and seal (which look probably original) and it was installed from the A-side. You are right it was right up against the lip and the end of the B arrow. I was just confused because the Bentley manual only states "press out old seal, press in new seal" and no other details. Also the original photo above (before I added the red arrows and text) kind of make it seem like the seal should be installed from the B side.
http://forums.pelicanparts.com/uploa...1292682752.jpg
If it goes in from the A-side, that is a really long distance to drag the seal surface along the bore of the guide tube. Do you recommend some kind of lubricant?
proporsche 04-04-2019 08:18 AM
I have never used any lube there to install it..maybe some other boys do i would not know.I have never seen a Bentley book.
First time i heard about it( i guess here), it sounded funny to me Bentley tell us how to work on Porsche;-)
Ivan
ps.
do not worry about the installation just make sure you are going strait in.I have a pipe which has a inner diameter as the tube for installation.
And one more thing , do not forget to replace the tiny o ring!! very important...also lube the tube on outside too for the TO bearing to slide nicely on it.I use Sachs lube...
2jmotorsports 04-04-2019 09:11 AM
I appreciate it Ivan!
kevingross 04-04-2019 03:39 PM
Pack the inside of the seal with grease, which is done to help make sure the "gaiter" stays in place. The gaiter is the metal spring loop. Smear a little grease on the outside of the seal to help it slide into position and avoid catching / cutting the seal's rubber surface.
Gordo2 04-04-2019 07:57 PM
Seal Installation
Here's how I did it:
http://forums.pelicanparts.com/porsche-911-technical-forum/941069-gordos-915-transmission-rebuild-8.html
Good luck,
Gordo
