Safety Wire!
I bought a safety wire tool and decided to try it out. I found this very handy 2 page PDF on the proper use of safety wire and cotter pins. I thought some of you might like to download a copy.
http://www.smittysrv.com/docs/safetywiring.pdf I used 10.9 bolts from Belmetric when I installed my trailing arms today. Had to use a carbide bit to drill the holes for the wire. It's probably overkill since the bolts are torqued to 70 ft lbs. And I used a double strand of .032 wire. But I always have been a 'belt and suspenders' man! This is the first time I've used safety wire and I did it mainly to learn how. I'd love to hear about other places on our cars that might benefit from greater fastener security. Or any other applications you might think pertinent. Please post your thoughts and pictures if ya got 'em. Robert |
Perpetual Reassembler
Nice job. Any more photos of how you drilled them?
I safety wired bolts in an aluminum airbox here. While the airbox is a stout unit with a built in pop-off valve I wasnt too happy about all the bolts in the intake path. I safety wired them so they wouldn't back out. It was a learning experience for me as well. ![]()
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer Last edited by 2jmotorsports; 03-28-2019 at 07:36 PM.. |
Also wired my thermostat after I rebuilt it and replaced the caps.
Jose - 1983 911SC Coupe Instagram: @joe_engineer 911 D I Y Blog: joe-engineer d o t c o m D I Y Vids: https://www.youtube.com/joeengineer |
I thought those thermostat nuts were impossible to remove baseline. A good application would be CV bolts.
Caveman Hammer Mechanic
Not really, far more experienced mechanics have weighed in. I tried safety wiring my CV bolts, proper washers is far more important/effective.
Reconstructing Constant Velocity (CV) Joints This will make your eyes bleed: https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_43.13-1B_w-chg1.pdf The first time I safety wired the cylinder base nuts on a radial engine with .041 stainless, my fingers were punctured and raw, there is a reason they give the new mechanic that honor...
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 03-28-2019 at 08:16 PM.. |
Senior Member
CV joint bolts. RoninLB used to wire them. Makes sense. Drill the hex heads. Whenever I am in triple digit speeds (not often) I think about CV joint bolts. Then I slow down. < wink >
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I've had to safety wire bolts for my motorcycles. Make sure you bend the end of the wire back around and down with needle nose pliers. Catching your hand on one is no fun.
Who knows why the FAA decides on stuff. That AC provides almost a hundred years of aviation knowledge/practices. Obviously portions are not applicable to cars, but the mechanical theory is universal.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
a bit over kill on some of that.
CV joints. i have had 2 come off, 2 different cars.
The difference between loose and tight on these bolts is just a few degrees of rotation, safety wire is not the correct process to prevent loosening of the bolts. Proper process is the key to fastener success.
cycling has-been
Most of the race cars I've seen wire the drain and fill plugs on the trans. That would be one of my firsts. Also, the drain plugs in the engine, and the oil tank are on my list.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
scumbag
I'm in the NordLock camp myself. They're great for CVs and headers where there's either high-stress or a lot of thermal expansion/contraction. They stay tight without over-tightening, yet aren't a terrible chore to remove (red loctite).
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
Chain fence eating turbo
Not to be a Debby Downer, but non of those posted would pass with me.
Used to be an aviation mechanic.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
AutoBahned
Exactly! safety wire prevents fasteners from dropping out (and bouncing around on the track) - it does NOT maintain the correct torque
But if the safety wire keeps the bolt from only backing out say 1/8th of a turn isnt this still better, in conjunction with the wrong procedures which most of us amateurs follow, than no safety wire?
Still here
I read in the CV thread, that the NL washers can be reused per the manufacturer but am not convinced yet due to the above. |
AutoBahned
the real use (as long as the bolt head is not damaged by somebody drilling them at home !!) is to prevent fasteners spewing out onto the track/road - you can read more in the small book commonly called "Screw to Win" since somebody channeled Grady above, I'll add that the late great Jim Sims (of National Weapons lab fastener expertise & fame) convinced me on here that the heads have adequate 'meat' to hold up if the drilling is done very carefully RIP to both, and to BA too |
