Size Tools needed to hand-turn a '73 911T MFI motor?
Hi everyone,
I'm a 1968 912 owner looking to upgrade into a 1973 911T project car -factory MFI- which I am going to see next week. It is a very honest car (I caught a brief peek months ago), however it has sat for ~20 years, and was briefly revived for one day ~10 years ago, only to sit again since that moment. The seller needs (and deserves) a fair offer. I can easily assess most of the car based on my 912 experiences, but my primary concern toward making an offer is the motor. I think the main gateway for me here is whether the crank will hand-turn or not, although I'm fairly sure some real work is in order regardless. I have a 912 so there is no easy flat 6 reference in my garage- what tool(s) or size of wrench do I need to bring with me to try turning this thing over by hand? It is far away, but I have access to a friend's toolbox near the car when I get there- I just need to pack any Porsche essentials- this item being one. thanks in advance! |
If the fan belt is present, You can turn the motor by turning the nut on the alternator and apply pressure to the belt. Depending on the alternator installed, it is a 22 (early) or 24 (late) mm nut. An open or box end wrench would be appropriate.
It not you will need to turn the nut on the lower pulley.
Thanks! That 22/24 figure was just what I needed!
Any other tips are welcome, hopefully there is good news to report next week... |
19mm on crankshaft
thanks for the replies everyone!
