Fuchs wheel pattern on 911S 1976
Hi, I have a Porsche 911S coupe 1976 original. I wont to put on it a Fuchs 16x7 in front and 16x8 rear.
That OK, It's a bolt on kit ? ? this pattern is good ? 16" x 8", ET/Offset 10.6mm, Bolt Pattern 5x130 16″ x 7″, ET/Offset 23.3mm, Bolt Pattern 5×130 Or tell me please the best pattern for the bolt on Fuchs kit Thanks. |
The 8" wheels won't fit on the rear, without rubbing, unless you install SC flairs.
The "best" for your car is a matter of opinion. I imagine there will be many here sharing their preference. Another consideration is the finish. Do you want black or polished pedals? I personally think the 6 x 15s with polished pedals look the best on mid year cars. |
Thank you Gordon,
I will buy a 16 x 7 for front and rear. I will put a 205/45/16 front and and 225/45/16 rear. I think it's a better choice |
Here's are a couple of pics of ischmitz's n/b w/ the 8x16 Et23.3 944 Fuchs w/225/50 x16 tires, 245/45 would be easier to fit and have a lower inertial cost than the 225/50s http://forums.pelicanparts.com/uploa...1124598850.jpg http://forums.pelicanparts.com/uploa...1124598839.jpg |
| All times are GMT -8. The time now is 01:22 PM. |
