lucifer572's Avatar
Decklid Grounding Straps
‘86 Carrera Coupé. Replacing factory whale tail with a Getty ducktail. Original whale tail has flat coated grounding straps what run from the mounting bolts between the tail and hinges to where the hinges are mounted in the engine bay. Are these grounding straps needed for anything with a fiberglass tail or can they be removed?
Old 04-07-2019, 08:28 PM
cycling has-been
bkreigsr's Avatar
'advanced search' is your friend....
Deck lid ground strap- why?
Old 04-08-2019, 11:21 AM
lucifer572's Avatar
Facepalm, curtsy, thanks.
Old 04-08-2019, 11:35 AM
