Deco seal
Hi.
Trying to find out a product number for the rubber seal that goes in between the bumper and bumper deco on a 1970 911.
I've searched and searched but can only find a similar seal for a 356.
Some the ads for bumper deco' show a separate rubber product, not the insert, but I cannot seem to find this sold separately.
Can't be that hard to find surely? Anyone know where to find this seal?
Old 04-10-2019, 02:22 AM
proporsche's Avatar
do you mean the rear bumper or front ??
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-10-2019, 02:52 AM
Ivan
The seal or backing rubber whatever it's called goes under the deco strip on the front and the back...
Old 04-10-2019, 03:44 AM
proporsche's Avatar
do you mean under the aluminium side bumper extensions?
Old 04-10-2019, 04:30 AM
proporsche's Avatar
this one
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=90150541751
Old 04-10-2019, 04:35 AM
Available from our host...
https://www.pelicanparts.com/catalog/SuperCat/5873/POR_5873_BDYBMP_pg1.htm#item2
Dave
1969 911T Coupe
1972 911E Targa
Old 04-10-2019, 04:43 AM
No, this is the insert that goes to the front. I need the rubber that goes behind the aluminium deco...
Old 04-10-2019, 05:17 AM
Originally Posted by dafischer View Post
The old part that came off was the shape of the deco trim, flat, rounded ends, I can't see how this rubber would work given the shape of it?
Old 04-10-2019, 05:21 AM
(man/dude)
Jonny042's Avatar
I think you can buy it by the meter..... it's known as "beading" which should help your search.
Part #64450543305 it's also used between the rocker deco and the body.
EDIT - Also part #999-911-198-40??
It's flexible enough to go around the ends, and flattens once you tighten the t bolts that hold the deco to the bumper.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 04-10-2019, 06:09 AM
