Need help identifying this part
greetings fellow members:
I decided to tackle some needed but dreaded task of search and rescue my '82 911sc targa from dried and cracked wires in the engine compartment. So many of theses wires are crying for help. This orange unit In question is attached to a bracket under the fuel accumulator is cracked and needs a replacement, but have no idea what to search for. hoping for some guidance and input. Thank you all Cheers Amir http://forums.pelicanparts.com/uploa...1554863701.jpg |
Oxygen sensor wire connector....discussed more in the link below
http://forums.pelicanparts.com/porsche-911-technical-forum/497025-o2-sensor-connector.html |
Thank you much Rsscotty. Seems that these buggers are quite problematic.
yep I had to replace mine.
| All times are GMT -8. The time now is 06:01 AM. |
