74 911 Targa Electrical problem
I installed a new ignition switch in this car and when I reconected the battery the horns go off with a consentent blast.
I have moved all the wiring and reinstalled the ignition switch with no change.
When I remove the relay the horn stopped and the car will start.
Any suggestions?
John Arvanis
Old 03-18-2003, 10:03 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Well,
you have somehow shortened the wire to the horn pad to ground. Maybe it got pinched during the install?
ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-18-2003, 08:07 PM
Thanks, I did pull the steering wheel to aid in the ign install.
so all of the wires are free and not grounded.
John Arvanis
Old 03-19-2003, 06:25 AM
i would assume the pin switch in the wheel is hitting. take the switch out and tape up the wire . see if she blows then. did it make you jump when you hooked up the battery?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 03-19-2003, 07:00 AM
Thanks I will try that.
And YES I did jump
John Arvanis
Old 03-19-2003, 08:22 AM
is the horn wire plugged into the horn button (pad)?
206 637 4071
Old 03-19-2003, 08:24 AM
No the wheel and horn is still off the car.
John Arvanis
Old 03-19-2003, 08:34 AM
i still would bet a dollar on the lonley wire on the horn switch. the insulation might be worn on that wire.
swap the horn relay with the hi/low headlight relay. see if the relay has fused at the points.
if you are buying parts.
the rubber grommet has aged poorly on the 72. check yours. i am also using the 914 steering wheel without the hub so i have to use the shorter switch. there are two sizes.
Old 03-19-2003, 08:51 AM
That is a great ideal, Thanks for the hint. Is the horn relay, the round black relay that is in the fuse box? If so I have swapped it with a new one with no change.
John Arvanis
Old 03-19-2003, 09:13 AM
what year is the car? you might unplug the wheel harness (i'm not sure if the horn wire is in there) to see if the short to ground is in the wheel.
my relay is by the batteries up front, but i have 'give them a slight coranary' air horns.
Old 03-19-2003, 09:19 AM
I have a 74 Targa
John Arvanis
Old 03-19-2003, 09:49 AM
