Msd 6al to distributor wiring
Car is a 78 sc with Weber carbs. There car has a main wire harness but no motor harness. I am building that myself. It has a msd 6al with msd blaster coil.I’ve got most of the other wiring figured out but am confused as to which wires go to the green wires on the distributor. I know it’s a coaxial and will either remove the end plug or try and tap into it. Not sure weather I’m supposed to use the white wire from the msd or the green and violet one. I’ve searched other threads but can’t find this information. Thanks
78 911 st backdate
87 944
00 996
Old 04-12-2019, 03:08 AM
T77911S's Avatar
green and violet.
I would try the green to the center conductor and the violet to the shield.
if it idles very hi and sounds funny, then swap the wires.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-12-2019, 03:48 AM
Thank you sir.
78 911 st backdate
87 944
00 996
Old 04-12-2019, 03:57 AM
