Tire advice Pirelli p zero rosso
Has anyone had these tires on there Porsche If so. Looking to know handling and tire wear. The reviews are all over the place and for the money. Not sure If there worth it. Thanks
Old 04-10-2019, 06:15 PM
kevingross's Avatar
Perhaps not the data you want, but I put a set on my Cayenne S tow vehicle a couple years ago. Really like them, they stick surprisingly well on this heavy vehicle. I mean *really* well. Wore them out after two years, went shopping for new tires a couple days ago. The Rosso's were cheaper than anything else I would consider using, so oddly enough I ordered another set.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 04-10-2019, 07:09 PM
Thanks for the response Kevin. How many miles did you get out of your tires?
Old 04-10-2019, 07:19 PM
cycling has-been
bkreigsr's Avatar
I just put them on my 77 turbo.
They were the only model available with both sizes I needed - 225/50, and 245/45.
I only have 800 miles on them, but I can tell you they are the noisiest set of rubber I have ever experienced on a P-car. Lots of highway hum at anything over 55 mph.
YMMV - depending on suspension settings. But, just going from Khumo's to these I found a whole new sub-set of road noises entering the cabin.
No complaints regarding dry, fair-weather traction. Wet seems to iffy at best, but then that might change once the mold chemicals have had a chance to work out of the tread compound..
Bill K
Old 04-12-2019, 11:00 AM
Former Options Trader !!!
A lot of it depends on what you personally want out of a tire, how you, drive and what kind of driving you're doing. A HUGE amount depends on what your car is like, what suspension set up, what year, what's the power like, and weight like.
Are you really buying these with a concern about how quickly they wear? Put it this way, their wear rate will be within +/- 5% of the all the other brands. If wear rate is a weighted concern of yours, I suggest all seasons and not ultra high performance.
Handling? Well, what are they going on and what kind of driving are you going to be doing and on what roads? What's your wheel size, weight and power of the car.
The point I am making is if you stick with some of the top rated tires there are, the differences are going to be so minor that unless you're tracking the car or your car is so perfectly dialed in you need a set of tires to match, then the differences are so minor it mostly comes down to personal preference.
Personally I don't care for the Pirelli's. For no other reason than I ran them on a 993 C4S I had which was a street car I used for some general fun driving and an occasional DE, I simply found them to be a lot louder than the Michelin's I had before them. Since then I have chosen others.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 04-14-2019, 11:08 AM
Wider is Better
wholberg's Avatar
A big issue is that there isn’t much else out there in 245/45-16 tire choices that are street tires.
Wider is Better
Old 04-14-2019, 05:47 PM
I have 205/55 and 245/45 16's on my '79. I haven't experienced the road noise that bkreigsr mentions above, but I typically drive my Targa with the top off so I'm hearing a lot of noise as it is - mostly the sweet sound of my 3.0. I only have about 1000 miles on them so I can't comment about wear as yet, but I like their performance thus far. Going from 225's to 245's may be skewing my impressions somewhat, but I'm very pleased with them, including wet conditions.
Jason
'79 911SC Targa
Old 04-14-2019, 05:59 PM
