Battery charge
what procedures need to be followed to charge a battery in an 88 911 w/o removing the batt?
Thanks |
Friend of Warren
Get battery charger. Connect postive lead from charger to battery. Connect negative lead from charger to a ground somewhere on the car other than on the battery! Charge battery.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
plug in the 110 / house cord after the battery connections are hooked up. when you are done, unplug the 110 outlet first.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Remove cables from battery prior to charging. If this is not a maintenance free battery, open the top caps to vent. Charge over night. You can test the battery charge with a voltmeter. A healthy battery should read about 12.5 or more and should not drop to less than about 10.5 when under starting load.
Chuck 1987 911 Targa 1962 C182 "Dirt is permanent. You can move it around, but you can never destroy it." |
I trickle charge my batteries at 2 amps...the early dual battery set-up, so I do leave the cables connected in order to charge both at once. These are gel cells, and so far, it seems to work just fine...I use a Sears charger that has the "automatic" feature of shutting itself off when the batteries are fully charged. I wouldn't buy a charger without this feature.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
if you car starts, then let it run for about 20 minutes....this should recharge the battery (if all electricals are in order)
www.swirlednews.com/article.asp?artID=501 The data in the CD-type disc decodes easily into ASCII computer text as follows, using 8 bit binary: * "Beware the bearers of FALSE gifts & their BROKEN PROMISES. Much PAIN but still time. (Damaged Word). There is GOOD out there. We OPpose DECEPTION. Conduit CLOSING (BELL SOUND)” * The damaged word would appear to be intended as “BELIEVE”. |
