Floor drains. Early SWB??
Its 21st century repair on the floor plan. I know the car will leak some where. Thus the water will stay in the cab. Its like a pool now. Do I fit vents in the floor . i live in a dry climate .
Lyndon
Old 04-15-2019, 11:55 PM
Lewinlucien's Avatar
At the air duct, on your hood in front of your windshield if you remove the screen grill, you will find a drain tube which can clog. If clogged, water can enter the cabin. The tube exits directly under the car. This may be a source of water.
Old 04-16-2019, 12:49 AM
My question is. After restoration it can never be water tight. But the floor is now water tight after replacement and sealing. Something will leak. So thoughts are to put drains or vents in the floor at low points. ???
Lyndon
Old 04-16-2019, 04:07 AM
No, you can make it leak free with some effort.
206 637 4071
Old 04-16-2019, 04:33 AM
I will take your advice. My expierance with Australian made cars is they leak from new.I've bought new quality rubbers so fingers crossed
Lyndon
Old 04-16-2019, 11:31 PM
