-   -   Going to install J West headlight relay but this is in the way? (http://forums.pelicanparts.com/porsche-911-technical-forum/1026896-going-install-j-west-headlight-relay-but-way.html)
Snitzler 04-16-2019 01:46 PM
I have a J West headlight relay kit and decided that it was time to install it but there is this connector in the way. WTH? Any ideas....
http://forums.pelicanparts.com/uploa...1555447550.JPG
86 911 Targa 04-16-2019 03:04 PM
Relays.
http://forums.pelicanparts.com/uploa...1555452085.jpg
http://forums.pelicanparts.com/uploa...1555452113.jpg
http://forums.pelicanparts.com/uploa...1555452199.jpg
The connector was relocated.
Gerry
sugarwood 04-16-2019 05:24 PM
No, it is not in the way
Originally Posted by sugarwood (Post 8348719)
http://i59.tinypic.com/nc14d4.jpg
I was able to install the relays. The directions were good.
I ended up using the ground near the front battery.
I will just Velcro it below the electrical connector.
I also used this as an opportunity to clean both grounds (Left of the fuse box and the ground bolt under the front bumper near the battery)
I used a wire wheel brush to clean the various ring terminal connectors and used dielectric grease, as well.
http://i57.tinypic.com/256eckm.jpg http://i60.tinypic.com/16c3vhz.jpg
When connecting the positive terminal to the battery,
I redid the brittle and fraying heat shrink tubing.
http://i59.tinypic.com/9fz7es.jpg http://i61.tinypic.com/jqkora.jpg
walt 04-16-2019 06:39 PM
Dielectric grease not good in that application, acts as an insulator. Just wire brush to clean and replace.
DerkPerk 04-16-2019 08:09 PM
I just recently installed the relay kit and adjusted the relay bracket to fit nicely over that connector. I do like the Velcro idea too mounted below it.
Snitzler 04-16-2019 10:33 PM
Thanks for the ideas, I like that velcro idea as well. Btw what is that connector for?
proporsche 04-17-2019 12:01 AM
take care of the rust under the battery ...nice job thou
Ivan
Red87911 04-17-2019 07:58 AM
In my '87, I found that the connector was for the frunk light as well as interior lights. My lights would flicker/turn off when I moved it slightly. Using a longer bolt, I placed the JWest relay over the top to help keep it stable and secure.
GenX Porsche 04-17-2019 11:47 AM
Shameless plug for a fellow community member, here is a recent YouTube video on the install. https://youtu.be/ObKnuH8eOVM
93nav 04-17-2019 02:54 PM
Good video. Nice and straight forward video on how to install the J West headlight relay kit.
