901 shifting question
Hi,
My rebuild 901 shifts like a dream. No grinding and shifting up and down (also from 2 to 1 while car is rolling no issue.
So should be happy dude ;-)
Only thing that feels weird is when going out of 2nd and 4th gear it feels a bit like I pull it out when there is still some load on. It clicks out.
Pulling clutch pedal gives a bit more then 1" (1.2" ~ 30 mm.)
So I thought maybe not enough un engaged(uncoupled) clutch, however I can shift in reverse without any problem(grinding)
Any idea or is this 'normal'?!
Thanks,
Bart
Old 04-21-2019, 11:23 AM
Under the radar
Trackrash's Avatar
I would tighten up the clutch adjustment a small amount and see if that helps. It does sound like the clutch may be dragging.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-21-2019, 03:20 PM
thanks Gordon will give it a try ;-)
Old 04-22-2019, 07:12 AM
