Can you convert a mechanical odometer 915 transmission to electronic
Can a 915 mechanical speedometer be converted to electronic?
Sure. Basically what you could do is attach a flying magnet to the Inner CV flange, and mount a Hall effect sensor nearby to pick up the signal. Then read that signal with an Arduino, and use that to drive a stepper motor in a Speedo. That’s basically what I’m doing in my 76. Sent from my iPad using Tapatalk Pro |
I did this in my 1975 car. I simply purchased an auto meter GPS sensor, and plugged it into an electronic Speedometer for my 911. It gives me really accurate speed, and works perfect.
It's in the car already
Part number
I thought about that but I just wanted to see if there was an easier way, thanks.
| All times are GMT -8. The time now is 03:41 AM. |
