				Engine ID
			Hi guys, I need some help identifying a 2.7 engine '76 or '77 vintage most likely.  It is installed in a '70 911T that my friend just bought last night.  He will be posting pics soon I hope.
				The engine number is 6141313 (if I made all the numbers out right). Also, where is the engine type number located on the case? Thanks!  |
			 Hilbilly Deluxe
			1974 911 (non-S).  Should be a type 911/92
	Tom  |
			My Porsche family tree says:
			s/n 6140001-6146625 is a 1974 coupe engine. 143hp at 5700 rpm!!
			Huey 86' 911 Cab Last edited by Huey58; 03-19-2003 at 01:52 PM..  |
			Thanks!
			James,
			The engine type number will be found stamped on a horizontal milled rib to the right of the fan housing support area.
	Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder'  |
			Warren, thanks, I will look a little more closely to find it.
			Pass side. The studs go into the chain housing. .......
			![]() IIRC, this is a 2.4T motor.
			JPIII Early Boxster Last edited by J P Stein; 03-19-2003 at 01:41 PM..  |
			JP, do ya have that camera in a holster on yer hip?
					   You seem to have a pic ready to go for everything.That makes it much more clear, thanks!  |
