Rennline Aluminum floor Board
Dear Friends,
I´m installing an Rennline Aluminum floor Board on my car
Rennline Aluminum floor board RENF03S - Rennline Design - REN-F03S | Pelican Parts
So, my questions are?
Do I need to install a Clutch Pedal Stop Plate (901 423 036 00) and the Pedal floor board (901 551 065 20)?
Old 03-06-2017, 05:13 PM
Do you have the pedal stop on the old wooden floor board? You could maybe transfer it over.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-06-2017, 05:44 PM
I just swapped mine from the old wood floor board on to my rennline.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 03-06-2017, 05:53 PM
911tracker85's Avatar
I think I also moved the clutch stop from my wood ones, and also get an adjustable stop for the gas pedal. don't recall now where I got that but think Rennline.
you can barely see that on this pic. you will want that as without you can mash the gas pedal hard enough to bend the linkage. dont ask me how I know.....
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 03-07-2017, 06:25 AM
I would put it in. if you don't you're probably going to snap the roll pin in your clutch pedal.
Old 07-17-2017, 06:36 PM
Harpo's Avatar
I transferred my clutch stop over to my new rennline pedal board. I suspect that the rennline board is thinner because I can't get clutch stop to get any clamping force on the aluminum board to lock in position. Has anyone else experienced this condition?
Old 05-18-2019, 03:39 AM
Registered Minimalist
75 911s's Avatar
It is thinner. I used two flat washers to make up the distance behind the board. You must be able to tighten the clutch stop bump so that you don't stress the clutch cable or roll pin on later models.
And to answer the OP. Yes. You need to drill out the rivets on the gas pedal stop and move it over (well at least on mine which is not a Rennline) Move both the clutch stop and the gas pedal stop over. You need to have someone watch the throttle to make sure you get WOT when the gas pedal hits the stop.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 05-18-2019, 05:16 AM
