Cevan's Avatar
Fuel injector installation - lube o-rings??
I’m having the injectors on my 3.2 Carrera refurbished. The injectors came off the fuel rails and out of the intake with some effort. I’m thinking that some type of lube on the new o-rings might be needed.
Am I right and if so, what is recommended?
1986 Carrera coupe - black on black
1972 CB500/4
Old 04-26-2019, 09:35 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
This stuff is won't be dissolved by gasoline:
https://www.aircraftspruce.com/catalog/cspages/sealube.php?gclid=EAIaIQobChMIt6HBrZ7u4QIVXp7ACh0v zA3GEAQYASABEgJNuPD_BwE
All other petroleum based stuff will disappear over time. I have used this stuff on thousands of fuel and oil related lines on aircraft. Anti Seize has abrasive material and is petroleum based.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-26-2019, 10:05 AM
porsher
aston@ultrasw.c's Avatar
I used a smear of engine oil.
I figured if it went away, i wouldn't care because the injector is seated correctly.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 04-26-2019, 12:09 PM
That 1 lb can of anti-seize can be passed on to your grandkids and the next generation.
A tube of Dow 111 is good too.
S
Old 04-26-2019, 06:26 PM
walt's Avatar
I'll second Dow 111. Recommended to me years ago, was able to find a small tin of it for cheap.
Walt
82SC 3.0
81SC 3.6
Old 04-27-2019, 04:53 AM
Vaseline
Old 04-27-2019, 06:17 AM
scottrx7tt's Avatar
I just cost in engine oil. Never had any issues
Old 04-27-2019, 06:32 AM
Racer
winders's Avatar
I use a very small dab of Redline CV2....
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 04-28-2019, 12:33 AM
I just did the injectors on my '74 and thought Hylomar, sold by Permatex as Permashield, #85420, was perfect. Fuel resistant and non-hardening, and you can remove the parts when ever you'd like....
Hylomar – This is a relatively new product in the a#ermarket but has been used by many OE manufacturers for almost 30 years. It is a polyester urethane-based gasket compound that withstands temperatures of up to 500 degrees without hardening. It’s non-setting and remains tacky, making repeated disassembly and re-assembly much easier for racing applications where constant adjustments under the hood are necessary. It can be used as a gasket sealer or in place of a gasket. Hylomar could very well be the adjustable wrench of gasket sealers, fit for any do-it- yourself or professional tool box.
steve
Steve Meltzer
'69 911E/bastard
Old 04-28-2019, 07:08 AM
Senior Member
Superman's Avatar
I use this on all O-rings. It makes them last virtually forever.
Mocha 1978 911SC. "Coco"
Old 04-28-2019, 09:03 AM
