Decel Valve
I noticed today that I have no hose on the decal valve. what does it connect to? the car runs great but I do get some exhaust popping on decal not sure if this is the cause. I am also running the car without the o2 sensor
Old 04-27-2019, 06:34 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
The ‘82 Yugo?
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-27-2019, 06:36 PM
The car is an 80 SC
watmough's Avatar
Yeah, mine (82 sc) has this same nipple disconnected (by me), as when connected to the vacuum source, it'll both hold at highish revs, and increase a normal idle to about 2000 rpm. Feathering the clutch works to lower the idle, but it can increase at will, which is painful in traffic.
The wisdom runs that these valves are pretty much wrong from the factory, and should only bypass air to slow rev drop at 18 mmHG (units?) vac, but actually will bypass air at more like 16 - 17 mmHg.
Disconnecting allows your revs to drop fast, mine drop very fast to 1200 or so, then slower to 950, with some popping when driving when coming off-throttle. And there was no popping before I disconnected mine, so I'd tend to blame this.
Old 04-27-2019, 08:07 PM
El Duderino
tirwin's Avatar
exhaust burble is a symptom disconnected decel valve. mine does. I kinda like it.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-27-2019, 09:44 PM
Vacuum unit is Inch Hg.........not mm Hg.
Watmough,
Found some decel valves to open at 22 in. Hg during tests and the good ones are closed @ 16 inch Hg. The most common problem with the decel valve is the inability to keep closed during operation well below 16 inch Hg.
Tony
Old 04-28-2019, 07:39 AM
