Brake fluid reservoir lines - leaky
After replacing the master cylinder and bleeding the system, I noticed brake fluid weeping around the blue braided exterior line going from the reservoir to the master cylinder.
I used a Motive pressure bleeder with air only at ~12 PSI. I'm pretty confident the weeping was from leaving the system under pressure longer than usually. I stopped to eat.
Where can I source those lines if I need them? I assume I just buy some length of it and maybe new plastic fittings that press into the master cylinder.
Another thought, any reason not to place a piece of absorbant mat under the assembly? I'm thinking a piece of that material cut to fit.
Old 04-10-2021, 07:31 AM
