What Does This Tool Look Like?
13mm Valve Adjustment Tool
PEL-UN120-8895 $44.95 :confused: ERIC |
:confused: CAN ONE BE MADE ....?
Here ya go/////http://forums.pelicanparts.com/uploads/911_valve_.jpg
Mike,
Thats the feeler gauge .. I know what that looks like but the one i am talking about is the 13mm wrench.. do you know what it looks like is it simply a 13mm box end that has an angled end? i am asking because it's $44 .00 seems like a lot. Thanks, Eric |
Mike I don't believe that is the $44 tool that Eric was asking about. At least I hope not. I paid less than $10 for the one you pictured. I think that the tool Eric is asking about is the one you use if you wish to adjust the valves using a dial indicator.
ERIK = TOOL
ha ha ha ha ,. sorry couldnt resist... ;) ;) ;) But seriously, you can bend you own wrench if you want. Or buy a specialty wrench from Snap-On for $35.00 |
Eric, get yourself a wrench from sears or ace and heat it then bend it.
[QUOTE]Originally posted by rattlsnak
[B]ERIK = TOOL ha ha ha ha ,. sorry couldnt resist... ;) ;) ;) I am not sure I get the joke (above), but yeah RT I think you know of the tool I am need. I will try to make one.. Thanks. Later, Eric |
It may be a combination tool, with a 13mm tube socket (like the VW plug sockets) and a screwdriver built in. It allows you to loosen the nut and turn the screwdriver without one or the other falling off.
Eric,
These are the only tools you need: - 13mm box wrench, offset may help - Feeler guage - Flat head screwdriver http://www.pelicanparts.com/techarti...just_pic20.jpg |
Eric, just buy a 993 engine from Harald...no more valve adjustments. Ha Ha....and think of the fun you will have.
I just used a standard box wrench, seemed to work just fine. Super photo by the way Kstylianos.
THanks Guys!! Super help! Charlie, Thanks for the great pic.
Thanks Eric |
| All times are GMT -8. The time now is 02:11 AM. |
