-   -   MSD users. A survey and a very simple question. (http://forums.pelicanparts.com/porsche-911-technical-forum/1028294-msd-users-survey-very-simple-question.html)
Jonny H 05-01-2019 12:14 PM
This survey question goes out to those who have any MSD unit replacing a 6 Pin Bosch CDI. Let me state that this is a survey that (I hope) will resolve an ongoing problem and benefit the community.
The MSD unit has a purple and a green wire for connection to the distributor.
Q: Does the green wire connect to:
A. The signal wire of the distributor (pin 7 on the original 6 pin connector)
Or..
B. The signal shield wire of the distributor (pin 31d on the original 6 pin connector)
Please vote but feel free to comment too!
Thanks.
bpu699 05-01-2019 02:14 PM
Whichever one works...
I did this a couple years ago, don’t remember this being a big issue... there were threads on here that walked you through it...
Jonny H 05-01-2019 02:19 PM
Trouble is they can both appear to work so many threads are incorrect. This isn’t about helping me out, I know the answer.
It’s more about spreading knowledge and understanding.
Jonny042 05-01-2019 02:38 PM
I voted signal from Porsche to Green on MSD.
Therefore Shield on Porsche goes to Purple on MSD?
My only knowledge on the subject comes from 30 second with google and 2 minutes with an MSD wiring diagram.
Jonny H 05-01-2019 02:42 PM
^. Can you explain which part of the MSD wiring diagram led you to make that choice?
VFR750 05-01-2019 02:46 PM
http://forums.pelicanparts.com/uploa...1556747059.jpg
This is what I did a couple of years ago. Still working
Using a "timmy2" plug
Jonny H 05-01-2019 02:50 PM
^. You are both correct of course but can you tell me how you made that choice based on info published from MSD?
VFR750 05-01-2019 03:06 PM
Jonny.
Good question. I can’t quite remember, but I know I spent a lot of time on the diagram and concluded green goes to “7”.
The comment on shielding is important. The violet went to “31d” for grounding the signal.
I’ll take a closer look on why.
VFR750 05-01-2019 03:11 PM
http://forums.pelicanparts.com/uploa...1556748667.PNG
Well, this doesn't help, except I searched the forums and followed this guidance.
November 22, 2016 is when I copied this.
VFR750 05-01-2019 03:20 PM
Jonny,
Since it is a magnetic pickup, does it really matter?
It is a pulse. (Semi-square wave) right?
Jonny042 05-01-2019 03:21 PM
The MSD breakdown on the function of the wires listed the polarity of the green/signal as (+) and the violet shield as (-).
The shield will always be (-) or grounded.
Jonny H 05-01-2019 03:23 PM
Ok, let me explain why I’m playing this game. We are getting increasing numbers of call outs to resolve ignition problems and mostly this is on twin plug or systems with custom distributors.
The one thing they have in common is they have MSD pickups inside. In EVERY single diagram ever made by MSD and in most vendors of distributors using their pickups, the polarity labelling is wrong by conventional electrical standards.
The two posters above both confirmed correctly that the green wire should connect to the signal, yet the green wire is labelled - in all MSD info. The purple wire is labelled + by MSD yet it is connected to the shield which is ground (-).
Furthermore all the MSD mag sensor wires are also labelled +/- incorrectly which leads to repeated wiring mistakes. If you give an auto electrician a wire labelled - he will connect it to ground every time.
I just don’t understand why I seem to be the first person to notice this?
Jonny042 05-01-2019 03:25 PM
EDIT!!!!!!!! I transposed my Green and Purple in my original response by mistake. In other words, got it completely backwards!!
Which in this case, according to JonnyH, is completely right. Sometimes you get lucky, not smart.
Edit 2 - I also apparently imagined reading about "signal" and "sheild" in the MSD info.
http://forums.pelicanparts.com/uploa...1556749451.jpg
So Jonny, if you go and put a good old fashioned needle type voltmeter (I keep one around and it's often very handy) on the MSD distributor pick up wires with the red test lead on the green/(-), and the black test lead on the purple/(+) you get a voltage spike in the positive direction when you turn the distributor?
Jonny H 05-01-2019 03:30 PM
^. Yep, you see it is wrong. GREEN IS POSITIVE, connected to signal as everybody knows!!!!!
Jonny H 05-01-2019 03:32 PM
I agree with you about the shield but according to MSD, green is negative. Check the MSD info for yourself.
Jonny H 05-01-2019 03:41 PM
Originally Posted by VFR750 (Post 10444949)
Jonny,
You bet it matters! If the sensor is wired backwards, the spark is fired when the rotor is half way between the posts. Often the engine will idle but not pick up. Also, the shallow slope of the ‘wrong’ edge cause dramatic wandering of timing as the revs rise.
VFR750 05-01-2019 03:44 PM
According to MSD, only their crank trigger is green = negative
All others are violet or black is negative. Including their own distributor!!http://forums.pelicanparts.com/uploa...1556750699.jpg
Jonny042 05-01-2019 03:47 PM
You can say that again....
http://forums.pelicanparts.com/uploa...1556750860.jpg
Jonny H 05-01-2019 03:53 PM
It’s an AC signal so that test doesn’t prove anything. On an MSD pickup the colours are orange and purple. Purple by conventional electrical standards is positive but MSD label this - . Orange is connected to shield but of course MSD call this +.
Then, on top of that, The wire colours on their sensor don’t match the MSD unit, so purple on the sensor goes to......yep green! And orange on the sensor goes to...purple. Hooray!
Confused yet?
Jonny H 05-01-2019 03:59 PM
That’s showing the sensor side but it is also incorrect. I had a distributor here today with that sensor listed on the top line. Orange/Black 100% needed to go to shield (-). I’ve corrected half a dozen of these so far. All wired by good auto electricians misled by this abuse of polarity!
