beepbeep's Avatar
installing short bellhouse 930 tranny into early SC
Title says it all...is there any unpleasent surprize involved?
Is short-bellhouse tranny weaker than typical 3.3L -tranny and what's the difference?
Thanx!
Thank you for your time,
Old 03-19-2003, 07:04 AM
The mounting hole have to drill in adifferent spot, well my 930 was switch to a 915 and they had to drill holes the make it mount so it should be just the opposite with the going 930-915 , the short bellhousing box is just as strong as the 3.3 box, The tranny is great for huge hp , so you should ok
Old 03-19-2003, 08:41 AM
beepbeep's Avatar
OK, it surely sounds good!
Engine mounting holes aren't our problem as this tranny is not going to be mated to porsche-engine so we have to make engine-to-transmission adapter anyway. It's just a question of where we are going to drill the holes
Old 03-19-2003, 10:11 AM
I bet it doesn't clear the torsion tube. but I could be wrong. How long is the tranny? If it is more than 23.75" it won't fit with out moving the motor back. At least that is what I found.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-19-2003, 04:25 PM
