Almost Done
Headlight Switch Harness Question
I recently upgraded to CarMagic LEDs for my dash as well as fixed all the bad lamps on the ventilation control panel. One item I added was a remote dimmer from CarMagic since my switch was acting up in that area
Removing the switch to add the dimmer was a lot more difficult because of the tight space etc, but I managed to get everything done, tested all worked and mounted the dimmer. I re-installed and then found everything wasn't working. Pulled switch out again and found the harness was disconnected from the main circuit so I re-installed BUT there is one solid red wire from the harness that wasn't connected to anything. I tested lights (which are on J West relays), turn signals, horn, all dash lamps, all electrical items etc and everything works perfectly. Can anyone tell me what that solid red wire in the harness is for? I am horrid at reading German wiring schematics but given everything is working I am confused by how what looks like a main feed could be excluded and get the results I am getting? I was going to multi meter the wire and pull fuses to see if that would point in one direction but thought asking experts would be a better starting point
1977 Targa
I appreciate any guidance
pictures if that red does need to be connected and to what?
Old 05-05-2019, 06:30 PM
Almost Done
no one out there with an answer :=(
Old 05-06-2019, 08:22 AM
Administrator
Dmitry at Pelican Parts's Avatar
Are you able to post a photo of the red wire and the general space?
Old 05-06-2019, 11:57 AM
Almost Done
headlight switch loom
the red single wire with female connector
this is a photo from website , real one is tucked up under dash and would require removing switch and emerg flasher to really show
Old 05-06-2019, 01:04 PM
ROW '78 911 Targa
timmy2's Avatar
Grey/Red wire goes to 58R terminal on headlight switch.
(Your wire should be grey/red.)
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-06-2019, 05:04 PM
Almost Done
Thanks Dennis..but its a solid 12 gauge red that is dangling BUT....
Problem solved though, our friends at Kroon Wiring in Europe kindly mailed me with this response
I think your headlight switch harness must have been replaced at some time for an earlier one.
The red wire was only in earlier headlight harnesses used from 1969 till 1975.
Starting from 76 it was removed.
That explains why everything is functional despite the dangling orphan
Thanks all
Old 05-07-2019, 03:57 AM
Kroon Wire Harnesses
Glad to hear we could solve this "mystery" for you !
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 05-07-2019, 04:15 AM
ROW '78 911 Targa
timmy2's Avatar
Good catch Gerald, harness replaced by someone, or one left over from previous years in the parts bin used during assembly. (Porsche assembler knew it would work)
6th wire on a 5 wire connector.
This is why pictures are so important.
Dennis
Old 05-07-2019, 09:18 AM
Almost Done
and I am grateful to Kroon for their help..they just won a new customer
Old 05-07-2019, 01:11 PM
Thank you !
Old 05-07-2019, 09:24 PM
